Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Cedric/M45/J30/Gloria
Old 08-17-2009, 05:28 PM   #1
coogrr99
coogrr99 Normal reputation
93 j30t idle occassionaly fluctuates from 1100rpm-2000rpm
on my 93 j30 my idle occassionaly fluctuates from 1100rpm-2000rpm at idle.not under load.most of the time it idles normal at 800-1000.When this problem happens it would raise and lower about every15-20 seconds.i have no MILs or codes.i cleaned out the maf sensor and i could not detect any vacuum leaks.could this be caused by a faulty TPS,bad O2 sensor,bad injector,clogged pcv etc...i know it could be a bad iacv but im hoping thats not the case ($750).is there a way to test and/or clean iacv.Any info would be highly appreciated. thanx
coogrr99 is offline   Reply With Quote
Old 09-14-2009, 08:33 AM   #2
swimshark
swimshark Normal reputation
Send a message via AIM to swimshark Send a message via MSN to swimshark
Re: 93 j30t idle occassionaly fluctuates from 1100rpm-2000rpm
There is a vacuum line on the J30 that runs directly to the IACV. I will get some pics tonight. There is a way to do a quick fabrication to allow you to clean it while the car runs. This sounds like the most probable issue. Have you checked the PCV on the side of the plenum? I know the hoses are a pain to work with so it wont be easy. If you are into upgrading some hoses, I'd recommend getting the silicone PCV and IACV hoses from Z1 for the NA 300zx. They will always be easy to work with and wont rot out.
My Car! Check it out.
swimshark is offline   Reply With Quote
Bookmarks
Google
Web AF
