Re: 96 ES300 gauge back lights
Check the FSMs stickied at the top of this forum for your vehicle. Yours is the equivalent of a Gen III V6 Camry. There is a bezel around the radio that you can pry loose with a tape protected flat screwdriver. Then the remaining finish panel around the cluster and A/C controls can be removed by removing the screws under the top edge of the cluster bezel and hidden under the radio bezel. Be careful pulling so you can disconnect any wires once the finish panel is loosened. Gauge cluster is held in by 4 screws. Hope this helps!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
