| Latest | 0 Rplys |
05-12-2009, 06:38 PM | #1 | |
Engine overhaul
After a few weeks of thinking, I came to the conclusion that my low oil pressure bugs me enough so, to getting my engine out of there and rebuild it.
I'm going to reground my crankshaft 75$ buy a new set of bearing 33$ new rear seal 15$
If they don't have it, I don't need It! |
05-15-2009, 07:04 PM | #2 | |
more pics
If they don't have it, I don't need It! Last edited by G0ldRush; 05-17-2009 at 03:23 PM. |
05-15-2009, 08:48 PM | #3 | |
Re: Engine overhaul
As bad as those bearings appear, I would consider having the rods checked. They may be egg shaped and if so you will probably be doing this again soon. The cam bearings are probably toasted as well. Do a good check on the rest of the engine. In the long run you will save time and money.
I would send the block out for a clean up, have new cam bearings installed, check the cylinders and hone. Buy an engine rebuild kit and get it back up to snuff. This may seem excessive but in the end it will be worth it.
05-15-2009, 09:06 PM | #4 | |
Banned
Re: Engine overhaul
You are better off getting a reman over rebuilding that engine.A reman is cheaper than rebuild.A reman from Jasper is at least $1200.00 with a 3 year 100,000 mile warranty.Rebuilding is more expensive due to machine work that is needed and rebuilt engines from a machine shop have a 2 year warranty and some will not stand behind their work
05-15-2009, 09:56 PM | #5 | ||
Re: Engine overhaul
Connecting rods with elongated big end bores can cause similar problems. If the rod bearings show a diagonal or uneven wear pattern, it usually means the rod is twisted. Rods with elongated crank journal bores or twist must be reconditioned or replaced. On some newer engines such as Ford's 4.6L V8 with powder metal rods and "cracked" caps, rods with elongated bores cannot be reconditioned by grinding the caps because the caps do not have a machined mating surface. So the big end bores must be cut to accept bearings with oversized outside diameters if the bores are stretched or out-of-round. In my case all the bearing that I took offf were not uneven good news for me. Regarding the cam well I'm taking the chance to leave it like that. This is where I'm going to bring my crank these guys are the best in town http://www.mecaniquerm.com/montreal_mechanic_e.html
05-16-2009, 07:24 AM | #6 | |
Re: Engine overhaul
Good luck.
I hope everything works in you favor.
05-17-2009, 03:20 PM | #7 | ||
Re: Engine overhaul
here's some pic
05-17-2009, 03:50 PM | #8 | |
Re: Engine overhaul
Very good, It never hurts to check. At least now you wont be second guessing yourself.
05-25-2009, 05:35 PM | #9 | ||
Re: Engine overhaul
Crankshaft came back from the shop, he regrind it at .020 and give me aluminium main bearing . Clearance at main .002 clearance at rod .002 either, I'M very happy about that. He did a perfect job. Tomorrow the tranny is going back in the van.
05-25-2009, 05:43 PM | #10 | |
Re: Engine overhaul
Nice details, keep up the good work!
05-27-2009, 07:06 AM | #11 | ||
Re: Engine overhaul
no get up at 80 90 KM, the oil level is good, I dont know whats wrong need some help here...
05-27-2009, 07:59 AM | #12 | ||
Hit me on the head
Denis
05-28-2009, 10:26 AM | #13 | |
Re: Engine overhaul
Ho forgot to say that my oil pressure is up at 50 psi cold and 45 psi at idle
05-28-2009, 02:25 PM | #14 | |
Ready for the big ride!
