| Latest | 0 Rplys |
03-26-2009, 02:17 PM | #1 | |
2002 miss-fire #3 cylinder
I took the van to auto zone for diagnostic and he said it's almost always the coil. Yet unlike most other vans my owner manual says I have EDIS not coil on plug. Which is the number 3 cylinder, is it difficult to access and can a non mechanic fix this? If I have to move a lot of stuff to get at the coil rack should I replace the whole thing? so far I haven't even been able to come up with a part number. Thanks! (total rookie)
03-26-2009, 07:04 PM | #2 | |
Re: 2002 miss-fire #3 cylinder
http://www.megamanual.com/ms2/EDIS.htm I would check your plug and ohm the plug wire. Normally you would loose two cylinders.
04-05-2009, 12:38 PM | #3 | |
Thanks for your answer. Does'nt tell me where #3 cylinder is though.
04-05-2009, 03:04 PM | #4 | |
Starting from the front its usually 1-3-5-7 and 2-4-6-8 on the other side but can be different. Use the manual they have a picture with each plug numbered. A lot of intakes are stamped with a number and the coil is numbered.
