Re: 2004 Quest S - Oil pressure light
From what you are describing it is perfectly normal, your oil pressure sending unit is working perfect. You said it happens as you are TURNING OFF your van in the driveway, it flickers. When you turn the car off the oil pressure drops. And seeing how you just cut the car off the indicator lights may only be visible for a split second if at all when one is getting a signal. Which is why it flickers when you cut the car off.
