Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Cefiro/Maxima/I30/I35
Old 03-05-2009, 01:58 PM   #1
jassingh
jassingh Normal reputation
99infiniti i30
Problem starting the car...it would start and die. If i start and press the gas it keeps on...if not it dies. HELP! The car has 130K miles and i don't know what to do..once the car is running i don't feel anything wrong as it runs good....maybe it could be the spark plugs or starter??
jassingh is offline   Reply With Quote
Old 03-06-2009, 12:42 AM   #2
Nahkapohjola
Nahkapohjola's Avatar
Nahkapohjola Normal reputation
Re: 99infiniti i30
Plugs [platinum] are to be changed every 60k, so better do it now.
If symptoms are only when engine is cold, points to TPS. Or cracked coilpacks having moisture shorting sparks (they start to die after 100k, only replacement helps).
Get self diag results; might [or maybe not] hlp. If TPS is bad, that should give an error code. Read this & links about TPS; generally functions like yours... can be checked via self diag & multimeter: http://www.cardomain.com/ride/748507/6
Maxima INFO; goto http://www.cardomain.com/ride/748507
Car Electronics http://www.cardomain.com/ride/748507/14
Nahkapohjola is offline   Reply With Quote
Old 10-18-2009, 11:58 AM   #3
EPVQ30
EPVQ30's Avatar
EPVQ30 0
Re: 99infiniti i30
i should change my plugs too.
SHIFT_99 SE-L 3 pedals
EPVQ30 is offline   Reply With Quote
Bookmarks
Google
Web AF
