Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > ES300/ES330/Windom
Old 03-02-2009, 03:15 PM   #1
socal1982
socal1982 Normal reputation
fog light replacement 99 lexus es300
I wanted to know how to replace the fog lights on a 99 lexus es 300?
socal1982 is offline   Reply With Quote
Old 03-03-2009, 04:02 PM   #2
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
Re: fog light replacement 99 lexus es300
Do you want to replace a burned out bulb or a broken lens?
Bulb replacement is usually easy...reach up behind the lower air dam and turn the bulb base to disconect it. There may be a clip you have to depress to allow it to rotate.
If you cannot get your hand back there or it is too hard to do without seeing it, sometimes the lens is held in place by spring-loaded tabs and can be gently pried loose with a flat-blade screwdriver or small pry bar covered with electrical tape (to prevent scratching). If you don't see any exposed screw heads, then this is probably the case. Otherwise, remove the screws holding it in then gently pry it loose. Then you should be able to see the bulb base to remove it.
The same above goes for replacing the lens itself...good luck!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Bookmarks
Google
Web AF
