Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > ES300/ES330/Windom
Old 03-01-2009, 03:09 PM   #1
shadoow
shadoow Normal reputation
Cracked Head Gasket?
Hi guys. Please bare with me as Im a newbie at this and dont know much about cars anyway. I'm in NZ and I have a 92 Windom 3.0 Any that I took in for a service about 3 months ago and was told that it had a crack in the head gasket and to get rid of it or it was going to cost $3000 to fix it otherwise. The temperature gauge never seems to rise. Occasionally there is a slight oily smell after driving it but nothing major and it never seems to go through water or oil. I had an oil change done when it was serviced and it hasnt seem to have gone through any. This morning after driving it a short distance it looked like there was a small amount of steam coming out of the bonnet but again not sure whether that was because it was a bit cold this morning, the engine, the dew that was on the bonnet drying off or just the heat of the engine hitting the cold air. I'm at a loss over whether it really is the head gasket. Any ideas please? Thanks
shadoow is offline   Reply With Quote
Old 03-03-2009, 03:00 PM   #2
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
Re: Cracked Head Gasket?
You'll have to pinpoint where the smoke/steam is coming from. It could be a leaking head gasket or it could simply be a leaking oil filter/cooler line, connection o-ring seal, or radiator hose clamp. Open up the bonnet when you start to see the smoke and look for the source.
A head gasket leak will usually show itself one of these ways:
1) coolant leaking from the block
2) coolant and oil mixing
3) oil and/or coolant leaking into the cylinders
4) oil leaking from the block
5) significantly poorer engine performance, heavy smoke/steam from tailpipe and/or engine compartment.
Burning/smoldering oil and coolant smell different...oil is acrid while coolant is sweeter. If you've been running for 3 months with this problem and no ill effects, then I'd suspect something else. A noticeable loss of power is reason to get it taken care of quick before major damage occurs. Barring that, more likely it is a leaking valve cover gasket, oil cooler o-ring, or cam/crankshaft seal. Hope this helps!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Bookmarks
Google
Web AF
