| Latest | 0 Rplys |
02-23-2009, 06:32 PM | #1 | |
Rodeo body lift
i have a 1997 rodeo 4x4 auto tranny. i can not find a body lift kit for is. has any one lifted a 97 if so any info will be a big help
02-23-2009, 09:14 PM | #2 | |
Re: Rodeo body lift
I've done a suspension lift which allows for decent sized tires. Body lift is something you only want to do if you want to go bigger then 34-35" tires, in which, anything bigger the IFS on these trucks will need swapped for a SAS.
Smiley on planetisuzoo.com has done a body lift on his 97, but I think his is a 5spd
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles |
02-24-2009, 06:27 PM | #3 | |
AF -Advisor
Re: Rodeo body lift
A BL is a good way to get an inch or two more room for a little bigger tire, but the big companies don't make BL's for auto equipped vehicles because of the linkage. They don't want to deal with liability issues.
There is one guy that does make custom BL's and has linkage adapters for Toyota autos, and he may be able to do it for your Rodeo. Check here He is very reputable, I've dealt with him many times.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
03-17-2009, 04:50 PM | #4 | |
Re: Rodeo body lift
03-20-2009, 01:50 AM | #5 | |
Re: Rodeo body lift
Yeah...for a $1k
Can't see the point in paying $900 more for that 1" inch over the 2" suspension lift I paid a total of $100 for....which equals a set of Calmini shackles, cranked front torsion bars, and a new alignment. I have a total of 3" of suspension lift, with the 32" tires and longer shackles. If you're referring to body lift however, yes, they are expensive.
03-20-2009, 09:32 AM | #6 | ||
AF -Advisor
Re: Rodeo body lift
You'll get more travel, more articulation, and a decent ride from that kit. With t-barcranking, for the ride height you gain, you loose the same amount in travel in the opposite direction (you can't get something for nothing), and it makes the ride harsher/stiffer. I like the kit they have for my 01 Trooper too.
03-20-2009, 04:53 PM | #7 | |
Re: Rodeo body lift
I guess if you *truly* need the lift then the money's justified; however, I can manage some pretty rough 4x4 trails with just the 2" lift and 32" tires.
Thousands of Isuzu owners have done nothing more to their front ends then the torsion bar cranking; take a look at planetisuzoo.com's website. Very few of them have used the Calmini kit at all; and those that have raised their front ends to the point of very limited travel have simply switched to the SAS set-up which is far superior anyhow if running a true high lift or running tires bigger then 35's. A lot of them have added additional items, i.e. ball joint spacers and flipped their ball joints, or changed out the oem torsion bars and added in heavy duty torsion bars....but their end result of the front end is mostly the same...cranked torsion bars. The add-a-leaf idea in Calmini's rear end makes for a very harsh ride in the rear; one should check out installing OME leaf springs, to replace worn out leaf's. These alone add an additional 1.5" of lift over factory leaf springs, and provide an excellent ride. My truck does ride rough, but rode rough BEFORE any lifting took place, that is thanks to the super stiff shocks that are on it, which are getting replaced soon. I do agree Calmini has some cool stuff, and perhaps this lift is suitable for most. But other Isuzu severe off-roaders have just either performed the above steps for the front end and/or switched to an SAS set up. I do agree if one is running a 3" lift or bigger, longer brake lines, shocks, etc are needed. In which case, check into independent4x, this guy specializes in Isuzu's and will set someone up nicely and affordably.
03-20-2009, 04:55 PM | #8 | |
Re: Rodeo body lift
Wanted to add - that kit you mentioned has all the same options I already installed, minus the brake line extensions and add a leafs. It comes with shackles and heavy duty torsion bars, i.e. for additional height, which IS what I have, but can be found cheaper.
