| Latest | 0 Rplys |
02-02-2009, 11:50 AM | #1 | |
Re: Traction Control System
I have a Chevy Venture 2000. First the " service traction system " started to come on, then the blinkers started to be wild; when I flash all 3 lights in the back go on like a Christmas tree! The lights for the turn left signal and right turn signal stay on in the dash although they are dimmed. Finally, when I use the cruise control and I use the blinkers, it disable the cruise control. So, everytime you use the blinkers you have to reset the cruise!
02-03-2009, 01:04 PM | #2 | |
if the floor pass-thru connector is corroded when you open it try spraying an electrical cleaner in to clean the pins because they will break off. the seal g.m. uses on the pass-tru connectors does not keep the moisture out.usually if the rear light circuit board is bad it will affect the cruise control
02-03-2009, 02:19 PM | #3 | |
The pass-thru connectors are located under the vehicule behind the driver seat? Where are the so called circuit boards located?
02-04-2009, 09:20 AM | #4 | |
the circuit boards for the rear lights are what the bulbs plug into. look for a melted or corroded spot. have seen the bulbs actually get melted in the board. g.m . has a flaw on these style vans where water will drain down and get into the rear light boards and cause problems. you have to take the rear lights off and see if you find anything wrong with them...
02-04-2009, 09:23 AM | #5 | ||
02-05-2009, 02:31 PM | #6 | |
This is a picture of one of the boards.
You might have to remove the bulbs to look for any burned spots or damage. If you have to replace the boards, make sure you seal the area from moisture and water as that's what usually starts the problem, water draining from above. You can use di-electric grease on the bulb bases before reinstalling them. The boards can be bought rather inexpensively on eBay.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
07-17-2009, 10:30 AM | #7 | |
Re: Issue with traction control - 2000 Venture
I recently replaced the rear tail light circuit board and corrected my problems: no more service traction control messsage, no more problem with cruise control when using the blinkers. The circuit board sells on Ebay about 25$ including shipping, I bought mine at my local scrap yard. Very easy to replace.
07-03-2011, 10:19 PM | #8 | |
Changing the tail light circuit boards solved the traction control problem for me as well.
Thread Tools | |
