Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > ES300/ES330/Windom
Old 02-02-2009, 03:05 PM   #1
rockinrodders
rockinrodders Normal reputation
Door locks constantly lock/unlock when driving
I have a problem with my 1996 Windom ES300
When I drive everytime I go over a bump, the central locking clicks the doors locked and then unlocked again. The door open light is lit red on the dash board.
Also when I leave the vehicle and close all the doors the red door open light remains on. I think the sensor button inside the drivers door is not being pressed in sufficiently and so it thinks the doors are open.
This is annoying when driving but recently my battery has started running down, presumably because this red light stays on all night, meaning the battery is flat in the morning.
Does anybody have any idea how I can either fix the problem or maybe just disconnet the sensor or the light etc?
rockinrodders is offline   Reply With Quote
Old 03-03-2009, 04:08 PM   #2
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
Re: Door locks constantly lock/unlock when driving
The problem is likely the wiring harness running to the driver's side door. The wires inside it have fatigued over time and many thousands of door opening/closings, causing them to cross-circuit. Either try to find a newer harness (new ones are likely impossible to find or very expensive) and inspect underneath the rubber boot for wire fatigue, or repair the broken wires in your current harness.
If you decide to repair, then make sure the repair connections are away from the area where the bending occurs and use similar gauge wiring to maintain flexibility. Good luck!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Old 03-28-2009, 05:16 PM   #3
ureda
ureda Normal reputation
I have a similar problem with my 1997 ES300 - the auto door locks cycle randomly and there is a short in the 7.5 amp dome circuit. Did you have any success finding a problem in the driver's wiring harness? thanks
ureda is offline   Reply With Quote
Bookmarks
Google
Web AF
