Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Cedric/M45/J30/Gloria
Old 03-23-2003, 09:25 PM   #1
voldemort
voldemort
'95 Infinity J30 Parking Brake Indicator
Hi
I have a 1995 Infinity J30 with 121k miles. Lately, the parking brake light does not go off even after I pull the parking brake release lever completely. I can feel that the parking brake has released but the light remains on. Can anyone suggest how I can check if the sensor has gone bad and how I would go about repairing this problem.
Thanks
Voldemort
voldemort is offline   Reply With Quote
Old 05-06-2003, 07:01 PM   #2
rrj30
rrj30
Lightbulb brake lights
The j30 brake system is 2 part, the normal brakes and parking. You should ckeck the parking pads.
rrj30 is offline   Reply With Quote
Old 06-17-2003, 05:38 PM   #3
kwaskow
kwaskow
Parking pads?? Two braking systems??? not hardly.
The parking brake operates the same set of rear pads as the normal brakes.
There is an adjustable sensor on the brake pedal probably. THis is typical. Also you might try pulling the parking brake pedal upwards slightly by hand to see if the light extinguishes.
kwaskow is offline   Reply With Quote
Old 06-18-2003, 03:07 PM   #4
boingo82
Can't polish a turd.
boingo82's Avatar
boingo82 +350boingo82 +350boingo82 +350boingo82 +350boingo82 +350
If the parking brake light stays on until you start going, and your battery light is also on temporarily, it means your alternator is not fully charging the battery anymore. That could be related to your problem.
Just because offense is offered, does not mean you have to take it.
boingo82 is offline   Reply With Quote
Old 06-06-2009, 12:06 AM   #5
DavidDock
Banned
DavidDock Normal reputation
Re: '95 Infinity J30 Parking Brake Indicator
The Infiniti G37 Coupe is a successor of Infiniti G35, powered by 3.7L V6 VQ37VHR engine which boasts 330 hp power, it was a more powerful engine version compared to the G37Sedan. Transmission is offered in either 6Gmt
manual transmission or automatic transmission.
Inside this manual you will find various useful information regarding Infiniti G37 Coupe’s Specs and Techs, maintenance, repair/service, engine overhaul and also controls and features.
Parking Sensor
DavidDock is offline   Reply With Quote
Old 07-16-2009, 03:21 PM   #6
Speedy_1234
Speedy_1234 Normal reputation
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Seems to me the sensor on the back of the parking brake got stuck
opcorn:
Speedy_1234 is offline   Reply With Quote
Old 09-14-2009, 08:39 AM   #7
swimshark
swimshark Normal reputation
Send a message via AIM to swimshark Send a message via MSN to swimshark
The braking system is two parts. Mine used to do this and I found out I just had to tug a bit harder on the lever/pedal itself and it would go off. If this isn't the case, I'd pull off your rear rotors and check the pads on the inside along with the inside of the rotor itself and look for grooves where the pads may have been rubbing a lot. Parking brake system only utilizes the rear rotors. The fronts are only used for normal braking.
My Car! Check it out.
swimshark is offline   Reply With Quote
Bookmarks
Google
Web AF
