| Latest | 0 Rplys |
Let's get Technical! Discussion for hardcore in-depth motor heads! |
12-30-2008, 04:40 PM | #1 | |
Im having a problem with my vigor please help
I own a 92 acura vigor GS and ive been having tons of problems with it. My cooling system seems to have to much pressure and my hoses keep breaking and my radiator cracked. I had the rad changed and the shop told me the cooling fans werent cycling proporly. Could someone explain what this means to me? Anyways, after i got it fixed another 3 hoses started leaking and i dont know what to do. Every time i drive it i randomly get a check engine light which is accompanyed by a huge power loss and only letting me go up to 3000 rpm then it seems to govern or something. This happens sometimes not for a couple hours at most but other times every 5 mins. While im driving i have to put it in nutral and turn the car off and then back on and the CEL goes away and i get my power back. Ive been doing this for almost a year now and i have no idea whats wrong. Also i get surging idle when i start it up in cold weather but it goes away for a while. Sometimes when i stop at a light when the engine is hot the idle surges again and gets lower and lower almost hitting 0. It has stalled a couple times from this. Also my battery drains every time i park the car. I charge it up to full and in one or two days its empty again. Sometimes when im driving the battery almost dies like all the lights turn off and the radio but it never has died from that. Last thing, the fan that defrosts my front window only has low speed and high speed wont work. The car seems pretty messed up but ive been reading alot about it and ive come up with a couple things. Could it be the alternator that causes most of this? Or MAF? or a problem with my throttle body? please help i need to drive this car until the summer.
01-01-2009, 05:50 PM | #2 | |
Lactose the Intolerant
Re: Im having a problem with my vigor please help
It sounds like you have a number of problems, least of which could be a bad head gasket pushing compression into the cooling jacket...but let's try to sort things one at a time.
I've noticed a LOT of the older Honda products are beginning to have issues with electrical demons. Most times in my experience it's from wiring insulation that's brittle and cracked from heat stress and age, and I've found a number of crossed up circuits and shorts on Honda stuff the age of yours and older. You story reminded me of an '89 Accord I worked on, it was also overheating, running the battery down, and had some other assorted electrical weirdness going. After a LOT of probing and searching, I found the engine wiring harness was a mess, and it was affecting the fans, the coolant temp sensor and the O2 sensor...so rather than try to find every bad spot (plus the wiring cracked more every time you moved it), I replaced that whole part of the engine harness. What you said about it laying down and refusing to rev over 3000 rpm sounds like what they do when they go into "limp" mode, usually from a loss of crankshaft position signal...the PCM will then only allow low rpm operation, and 3000 rpm sounds like the magic number I remember... I think yours uses a "wax valve" type of mechanism to regulate cold start idle, based on coolant temp. If you've been overheating for some time, this valve is probably damaged and causing to idle to surge, although there could be other explanations, this jumps to mind as I've seen it happen before... As far as the pressure in the cooling system goes....that can be a very bad sign, but hard to diagnose from a distance...one good indicator in general is if there is a lot of pressure in hoses before there is any warmth after a cold start...this usually points to a compression leak. But if the problem is limited to operating temp, the fans probably play a huge role if they aren't working correctly. Again, wiring may be the issue here. Upshot is, you need someone with some experience to sort through all this...shotgunning it with new parts and hoping is probably not gonna cut it...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
