Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Thread Tools Search this Thread
Old 10-06-2008, 07:11 PM   #1
2subs
'99 Suburban extremely hard on fuel pumps
Howdy, new member here, I'm beside myself with anger tonight.
1999 K1500 Sub, 186K, Runs great when it runs.
I replaced the fuel pump and sender last December with Delco
parts, and it quit working again mid-August. Drained tank and
replaced again with Delco. Here it is the sixth of October,
I get home from work, and my wife tells me that the truck
won't start again. How can two pumps go bad in such a short
amount of time?
I've done all the work myself, the job isn't too bad, the worst part
is draining the tank. Where are all the grounds located. I have a feeling
that something else is afoot here. Did I miss something?
I also have the telltale dancing fuel needle. Is this a ground issue,
or a sender, or both. Any guidance would be greatly appreciated.
Scott
2subs is offline   Reply With Quote
Old 10-07-2008, 10:14 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: '99 Suburban extremely hard on fuel pumps
Wiring and plugin and power and grounds are very importain.
What is failing on the old pumps?
When no start check for 12 volt power and good ground at the wires going to pump.
Have they been run low on fuel in tank?
Dirty fuel or stopped up fuel filter?
MT
MT-2500 is offline   Reply With Quote
Old 10-07-2008, 01:20 PM   #3
2subs
MT,
Thanks for the reply. I'll have to drain again, and check for power
back there. I can't say that I know for sure that the pumps have
failed, I'm just guessing. I get no sign or sound that anything is
alive back there.
Would a bad pressure regulator wear a pump out prematurely?
Does anyone have a schematic of where all the grounds are located?
What drives me nuts is that my '99 5.7 K2500 Sub has no wavy fuel needle, and starts without hesitation.
Let me know if anyone else has bumped into anything unusual. If the pumps keep going out at this rate, I'll have GM back on their feet in no time.
Scott
Old 10-07-2008, 02:39 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
Are you running the tank low of fuel?
Fuel pump ground is inside left frame rail near front of transmission.
Relay ground is right rear cylinder head.
Fist check voltage and ground and wires before the get to tank.
Pumps are made to run under normal pressure all time.
Running at high pressure.
Running low of fuel.
Low voltage.
Restricted system and dirty fuel.
Will kill Them dead.
MT
Old 10-07-2008, 07:11 PM   #5
2subs
MT,
I changed the fuel filter last December with a Wix unit. I rarely let
the tank get below 1/2 full because of the gas keeping the pump
cool. I don't know if I have a dirty fuel system, but I don't buy gas
anywhere but "name brand" stations I guess.
Where do I check power to the pump without dropping the tank?
I will check all grounds also. I wonder if the jumpy fuel gauge is indicative
of the pump working too hard to keep pressure, like it's fighting a bad
pressure regulator. I'll keep narrowing down options.
Scott
Old 10-07-2008, 07:24 PM   #6
j cAT
Originally Posted by 2subs
MT,
Scott
whenever replacing a fuel pump the pump relay should be replaced or opened and inspected for contacts being burned...
on your needle, fuel gauge ...is it wondering or vibrating ? If it vibrates rapidly this is usually the dash console...but could be grounds that look good but have to be removed sanded to bright metal and then re attached....
after the fuel pump is replaced check fuel pressure....this will give info on what maybe causing the pump to fail...
j cAT is offline   Reply With Quote
Old 10-07-2008, 08:18 PM   #7
2subs
J cAT,
The needle is vibrating. I couldn't find the ground on the drivers
side near the front of the transmission but I'll keep looking. I found
all kinds of grounds at the rear of the motor on the passenger side.
I'll check fuel pressure after I replace the pump again. All grounds that
I can locate will be cleaned up. I'll replace the relay, and probably
the pressure regulator while it's all apart. It's too nice of a truck to give
up on just yet, but I'll admit I'm frustrated.
Scott
Old 10-08-2008, 09:10 AM   #8
MT-2500
AF - Advisor
MT-2500's Avatar
J cAT,
Scott
Clean and check all grounds.
Also you can run a extra ground on it.
But on your main problem of hard to start always test it out when hard to start.
Could be other ptroblems besides fuel pump or fuel pressure.
Remember proper testing is first thing to do.
Good luck
MT
Old 10-19-2008, 05:08 PM   #9
2subs
Update:
Well, I cleaned up, and rewired the pump ground that runs to the crossmember just in front of the tank. The fuel pump runs again, but
it is throwing a SES that I need to pull.
I hope that's all it was, I have read some past posts where this was the
problem. I hope it continues to run, and I will pull the code and see what's
bugging the ECM.
Scott
Old 10-19-2008, 06:47 PM   #10
MT-2500
AF - Advisor
MT-2500's Avatar
Update:
bugging the ECM.
Scott
Not only in in past post but in this post check the ground was metioned several times,
Thanks for posting back how it went
MT
Old 10-19-2008, 08:25 PM   #11
777stickman
If your '99 is an OBS (Old Body Style) (looks like a '95) I may be able to add some tips.
If it's an NBS (New Body Style) (looks like a '00) I'm out.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
777stickman is offline   Reply With Quote
Old 10-19-2008, 08:32 PM   #12
2subs
MT,
I appreciate the heads up on the grounds. I'm upset at myself for
probably tossing out a perfectly good AC/Delco pump back in
August.
777,
I have the 1999 OBS, last year I believe of the larger Subs. I'll take any
hints and pointers I can get.
Scott
Old 10-20-2008, 10:29 AM   #13
j cAT
MT,
August.
777,
Scott
what about that rapidly vibrating fuel gauge????
Did the ground cleaning solve that problem to...? the needle problem has had some give up on repairing..
Old 10-20-2008, 07:32 PM   #14
2subs
j cAT,
Nope, didn't cure the dancing needle. I'm going to check all grounds
under the dash, and see what I come up with. Time to go to Helms
and get the proper FSM. Nice to know where all the grounds and wiring
run.
Scott
Old 10-21-2008, 11:09 AM   #15
j cAT
j cAT,
run.
Scott
the dash instrument panel is most likely causing this....as others have also found this to cause their problem...
grounds and conectors in the area..
Search this Thread:
