Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 09-08-2008, 08:22 PM   #1
mazsand
mazsand Normal reputation
Camshaft end plug seals
I will be changing the valve cover gaskets on my 97, 3.0L caravan and would like to put new camshaft endplug seals on also. Is there an easy way to get the old plugs out? How about loosening the end caps on the cam to assist in removing the old and install the new endplugs?
mazsand is offline   Reply With Quote
Old 09-08-2008, 09:52 PM   #2
littlebitofinsanit
littlebitofinsanit Normal reputation
Re: Camshaft end plug seals
book says use screw drivers and carefully pull out careful not to scratch cam shaft use cam bolt length of pipe two washer and slowly tighten and will even press make sure to apply thin film of grease
you"ll be alright
littlebitofinsanit is offline   Reply With Quote
Old 09-09-2008, 07:21 PM   #3
mazsand
Sounds good.
But I would like to know if there is an easy way to remove the plug on the end of the camshaft. Is loosening the end bearing car by the plug, going to loosen it to assist in removing.
Old 09-14-2008, 08:27 PM   #4
littlebitofinsanit
advanced auto seal removal tool
you"ll be alright
Old 11-08-2009, 12:15 PM   #5
raj49
raj49 Normal reputation
Hi Just wanted to know if you replaced the camshaft endplugs on the 3.0L caravan? Did you just pry them out and tap new ones in?
Please reply. Thanks!
raj49 is offline   Reply With Quote
Bookmarks
Google
Web AF
