Thread Tools Search this Thread
Old 08-05-2008, 11:51 AM   #1
jaykay640
Audi R8C LeMans 1999 Provence Moulage 1:43
Hi everybody
Here’s a new build report from me. I should rather be working on my little Tameo Lotus 72 after a long time without any serious modeling ( due to other things I had to do ), but while it was sitting around untouched the old paint problem reoccurred :-( I decided I was fed up with that and finally throw my resin chassis away and use the metal one. That means though I had to order some new decals and I’m waiting for them now.
Anyway, just when I decided to restart it all once more, my latest ebay-prey arrived from England. It’s the 1:43 scale Provence Moulage kit of the Audi R8C.
In 1999 Audi tackled the Le Mans 24h for the first time. They entered two R8R open top cars that were built up in Ingolstadt and two R8C coupes built by RTN in England to find out which concept was the better option. Unfortunately the decided to carry on with the open cars. Unfortunately for me because I much rather like closed prototypes, but success at Le Mans showed Audi had a point :-) The development of the R8C wasn’t a complete waste though, because RTN carried on from there and developed the LeMans Bentleys, whose last evolution won LeMans outright in 2003 ( well… because Audi had to let them :-)
The kit looked quite nice and not like too much work so I had to give it a go.
Unlike the BBR 911 GT1 I built before it looked like there were no major corrections to do and I could focus on adding some nice details. BBR did kits of both the R8C and R8R as well but I don’t really wanna know what they look like out of the box. The R8C is increasingly hard to find ( more or less only ebay ) and more popular than the R8R it seems. I have that one too and got it for a “whopping” 8€ :-)
There are not too many reference pictures of the R8C around, but I was able to take a few at Goodwood last year. Right before leaving I found out there was one on static display in the Audi pavillion and before they could kick me out I took some pictures I will add to the build report. Since it’s only a curbside 1:43 they should be enough.
The Provence Moulage kit was a positive surprise. The resin body was crisp with very fine graphics, looked quite symmetric and properly shaped.
Along with that you get the usual bits like turned aluminium wheels and rubber tyres, rear wing, a seat and no less than 4 (!?) mirrors…none of which really has the right shape :-)
Interior with ground plate:
Vacform clear piece for windows and headlight covers
A PE fret with the “usual” bits like diffuser, wing endplates and detail stuff:
The decals ( the livery is not too wild…):
And the “instructions”. They are typically for these PM kits a coloured A4 copy with pictures of the built kits with some notes and a few very small pictures of the real thing. You should know what you’re up to with one of these kits :-)
The funny thing is, that both built cars on that sheet have the rear wings mounted facing downwards to the rear. That would make for some interesting driving in reality :-)
I will do the No10 car, that was driven by Perry McCarthy ( and misters Wallace and Weaver ) who also famously was the first ( black ) “Stig” on Top Gear. I’d also highly recommend to read his biography “Flat Out – Flat broke ( Formula 1 the hard way )” which is hilarious reading!
I have already made some progress with this build and will soon post some pictures of that. Hopes are high this won’t be another endless build :-)
Thanks for looking!
jaykay640 is offline   Reply With Quote
Old 08-05-2008, 12:25 PM   #2
tuned.by.twenty
AF Vendor-TBT's Owner
tuned.by.twenty's Avatar
Re: Audi R8C LeMans 1999 Provence Moulage 1:43
It looks to be an interesting build! I'll be watching.
tuned.by.twenty is offline   Reply With Quote
Old 08-05-2008, 12:27 PM   #3
Decs0105
Decs0105's Avatar
here we go again, Masterpiece in the works opcorn:
Decs0105 is offline   Reply With Quote
Old 08-05-2008, 02:31 PM   #4
klutz_100
klutz_100's Avatar
Exactly!
I love it when he says "shouldn't be too much work, just a quickie"...and then re-works the whole kit!
Modeling porn -yay!
Old 08-09-2008, 07:56 AM   #5
jaykay640
Hi there
Here we go with some actual building progress.
Naturally I first worked on the body. As I mentioned before it was quite nice over all and I had to address only two “major” issues.
First up here’s a picture of the primered body after this first batch of mods i made:
No1 were the “side pods” or rather the radiator ducts in them. The holes were only about half as deep as necessary ( casting issue I’d say…) and there was only space for half a radiator each. To make things even easier the kit comes without any radiators…:-).
I carved away all the material from the insides, then built up the holes with sheet plastic and refilled the back sides with polyester putty. Here’s a close up:
I also deepened and thinned the walls of the turbo ducts on top of the side pods.
The other issue was the opening for the windows ( or DLO as the car guys say :-). It was too narrow ( not high enough ). I lowered the lower edge by 0,8mm on the mill. That was helped by the fact that this edge runs horizontally.
Because of that I also had to move the NACA-duct on the nose forward, but it was too small anyway. Here it’s still not right but will be fixed.
I also thinned out the roll hoop because it hardly left enough space to look out of the car :-)
At the rear end the kit provides decals for the lights….. Couldn’t leave it like that.
I lowered the surface for some extra bits to be added and also thinned out the wall thickness of the bodywork’s trailing edge.
In the roof i milled these venting holes. The kit also provides stickers for these…..tststs.
Then I rescribed and deepened all the shutlines. I was afraid they would disappear with all the layers of paint to come.
I also deepened the headlight housings. This one here looks a bit crooked but that will be fixed.
Finally I thinned out those fins behind the front wheels. The had to be more massive for casting again and I sanded them thin from the back side.
Here’s a picture of the diffuser after priming ( soldered from kit PE bits ) and those two planks that go under the sills as the ground plate in the open area behind the front wheels.
That’s it for now. More filing and sanding to do and other details to come.
I didn’t photograph every single little step this time but I think you get the picture :-)
Thanks for looking!
Old 08-09-2008, 08:08 AM   #6
klutz_100
klutz_100's Avatar
Very nice prep work.
Essential too, I would say. I can't think why they went the decal route for those roof vents!?!? yuck!
WTF does "DLO" stand for?!!?
(I wanna be a car guy too! )
Old 08-09-2008, 08:33 AM   #7
jaykay640
It's the Day Light Opening....
Yes....i laughed too when i heard it first... :-)
Old 08-09-2008, 08:56 AM   #8
klutz_100
klutz_100's Avatar
Thanks!
and are the headlights NTIs (Night Time Illuminators)?
Old 08-11-2008, 04:46 AM   #9
sjelic
sjelic's Avatar
Huh, that is what I call determination. What do you use for panels? Which scriber?
Sasa Jelic
SCALEMAKERS
sjelic is offline   Reply With Quote
Old 08-18-2008, 05:31 PM   #10
jaykay640
For today i have a very brief "1-picture-update" for you guys.
There was room for improvement in the "PE-area" of this kit so i made a bunch of additional parts to soup the details up a bit ( or two...:-)
There is for example a better detailed rear wing support, some coolers, brake discs and calipers and not to forget a less fat Audi logo.
You'll see what they all are once i mount them i think:-)
It’s often a lot of work to get them done but once I have the parts in my hand and can put them on the model they make me smile…
The top right sprue is wrong in the picture. Those are parts for a 1:24 Bentley, but i didn't notice before it was too late to take a new one...
So that's it for today.
Sjelic....i use various things for scribing, like the proverbial backside of a No.11 blade, SRC scribers, files and sand paper. I can't get it done with just one tool.
Cheers!
Old 08-19-2008, 03:34 AM   #11
sjelic
sjelic's Avatar
Cheers!
That is the answer I wanted to hear, I thought that I was the problem
Great PE sets btw.
Sasa Jelic
SCALEMAKERS
Old 08-19-2008, 06:55 AM   #12
robrex
robrex's Avatar
Uh....Can you do me a favour and list all the kits you'll be building next so I don't pick the same kit? I'm afraid you'll make me look bad!
This is simply superb!
Rob
robrex is offline   Reply With Quote
Old 08-19-2008, 04:43 PM   #13
jaykay640
Well Rob i think you’re one of those people who really don’t need any such list! Besides….it changes on a nearly daily basis:-) If I can stay away from starting new stuff I’ll be busy for the rest of the year with this Audi, the Tameo Lotus 72 and possibly the MP4/4.
During that time you can without a doubt easily build a whole pile of excellent models :-) Anyway…what are you building right now? Did I miss it?
Since I’m at it here’s a bit more building progress.
One weak point of all these 1:43 modern GT/LMP kits are the wheels. Borranis and the likes are well suited for the PE/turned aluminium rim pieces the manufacturers use but O.Z. rims just don’t work! Here are the originals for comparison:
If you see those etched „stars“ on the kit sprue they just don’t have the right thickness. They might make a good fan or mixer though :-)
I was thinking for a while how to make proper parts and the lathe and mill were nearly up an running when i discovered an easier solution……cast the spokes off a friend’s Minichamps diecast!
Now you could say….why not just stick those on the model!? But they weren’t that nice. The brake discs were “unpaintably” connected with the rims and besides there were no brake callipers….
The kit rims and brake “discs” ( blobs actually…) weren’t impressive either and the front rims had yet another problem ( apart from being too narrow for the rubbers ). Like in all those kits they were massive aluminium at the back with a small hole for the axle. Normally that’s fine because you don’t see that area but the R8C is one of a few cars that has open front wheelarches towards the car’s centreline, hence you see the back of the wheels ( see picture at the beginning of this update ). So I turned new aluminium rings for the fronts and opend the kit ones for the rear wheels. They could have stayed but I decided to use the same system for mounting all the wheels to not make things too complicated.
The cast Minichamps-spokes were too thick so I chucked them on the motor tool and thinned them from the back with files and sand paper. This is how the parts then looked:
The little aluminium things are for the wheel centres and you can see the etched brake discs and callipers after cleaning and ready for paint.
I put he pieces together with CA glue, primed them, sanded them, painted ZERO gloss black, sanded, painted Alclad Aluminium, added O.Z. decals and covered them with 2K-clear and now they look like this
The tyres were stripped off a funny fine tread using the motor tool and sandpaper. Later on they will get Michelin decals and some clear on the sidewalls.
The rims are not perfect. The spokes are not all really centred and they have some dents and blemishes here and there. I could easily have spent another bunch of hours fiddling with them but I decided they’re o.k. for this model. If I really get bored I’ll give them another try on another kit :-)
They do have a proper volume which was my goal and they’ll need it because in the end they’ll actually carry the weight of the model. I hope they don’t bend over time!
So far for now. CU for more!
Old 08-19-2008, 06:47 PM   #14
Robi J
Robi J's Avatar
Oh Jay, I love your approach to the kits !!! And now, with the correct wheels (fantastic) will be a killer for sure
Robi
Robi J is offline   Reply With Quote
Old 08-20-2008, 12:17 AM   #15
sportracer02
sportracer02's Avatar
Good start, jaykay!
I always loved this car and look forward for your progress
Micha
Bookmarks
Search this Thread:
