Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 07-31-2008, 11:00 AM   #31
robertbassin5
robertbassin5 Normal reputation
Re: Engine light coming on for awhile and then going off for awhile.
No I have not change the KS wire yet. But I noticed that the wire is not even close to the spark plug wires. I use 87 octane. All these problem started after I had the motor rebuilt.
robertbassin5 is offline   Reply With Quote
Old 07-31-2008, 01:43 PM   #32
silicon212
AF -Advisor
silicon212's Avatar
silicon212 Normal reputation
Send a message via ICQ to silicon212
It helps to know this stuff! If that's the case, your engine may now have slightly higher compression, considering it was probably bored, decked and the heads milled. All 3 of these things can raise compression.
Try running 89 octane in it and see if that helps.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
PC Club is dead. Long live PC Club!
silicon212 is offline   Reply With Quote
Old 07-31-2008, 03:38 PM   #33
robertbassin5
Well I changed the KS wire and I noticed that the existing wire was slightly greenish and copper looking. Looks like the wire might have been bad. After changing the wire connector and driving around for about 5 mins. the light turned itself off.
Old 07-31-2008, 07:08 PM   #34
j cAT
j cAT Normal reputation
you most likely fixed it... the KS output is a very low a/c volt...if you have a corroded connection this will happen and this is very common...
good luck
j cAT is offline   Reply With Quote
Old 07-31-2008, 07:28 PM   #35
robertbassin5
Man I really hope so.
Old 08-03-2008, 02:42 PM   #36
robertbassin5
Well guys guess what? You'll know I changed my KS connector. I put about a half tank of unleaded plus in it and drove about 95 miles, then the light came back on. Now what do I do?
Old 08-03-2008, 09:03 PM   #37
j cAT
it is possible that the computer has to relearn the Ks voltage output...the KS produces a/c voltage when shocked as in engine detonation..
can you hear engine noises...maybe the engine has mechanical noise thats creating the KS output to be incorrect...95mi then it comes on is strange unless something else occured..
if your engine is running too hot this can cause detonation..what temp does it run at ???
Old 08-03-2008, 09:08 PM   #38
robertbassin5
I don't hear anything that is knocking or pinging anywhere. My engine temp is about 195 F. Which I believe to be normal. When the light comes on I dont hear anything different.
Old 08-03-2008, 09:19 PM   #39
j cAT
this I feel is a bad connection then as the engine appears to be running at normal temp and does not make any noises...
are you very sure you checked all the grounds ???? this will also cause all kinds of problems such as yours...battery , frame rails, engine etc...there are many and with the job they did it is very common for the rebuilders to forget to secure and clean surface before securing the grounds...
Old 08-03-2008, 09:30 PM   #40
robertbassin5
I checked everything that I can see. I am about ready to go buy some C4.
Old 08-03-2008, 10:27 PM   #41
briand069
briand069 Normal reputation
I'm not 100% positive on this, but I recall reading somewhere that knock sensors use a special sealant (silicone?) or no sealant at all on the threads. This might be worth a shot checking into since the engine has been replaced and maybe the shop put the wrong stuff on it. Other than that, I suppose it's possible during the install that a wire got pinched somewhere in the harness and it is causing your trouble. Good luck, and I'm sure you'll figure it out soon.
briand069 is offline   Reply With Quote
Old 08-03-2008, 10:54 PM   #42
robertbassin5
Took the knock sensor out and there was no sealant of any kind on it.
Old 08-04-2008, 12:00 PM   #43
j cAT
replace the KS sensor they probably dropped it.....
Old 08-04-2008, 10:47 PM   #44
briand069
Is it possible the engine block was painted and the threads for the knock sensor have paint in them? Also, you really need a manual for your truck to follow the troubleshooting steps for checking the circuit as well as the sensor. It's possible the new sensor you bought was dropped and it's bad as well. Do you have a scanner that you can watch the knock sensor with?
Brian
Old 08-05-2008, 04:22 AM   #45
robertbassin5
I have already ran all the checks for the knock sensor and they were ok.
Bookmarks
Google
Web AF
