Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 07-27-2008, 10:44 AM   #16
j cAT
j cAT Normal reputation
Re: Engine light coming on for awhile and then going off for awhile.
on the intermittent p0327 torque the ks [knock sensor] to 14ft lbs...leads to KS must be clear of plug wires high voltages will cause this problem so plug wires run near these are a problem the resistance of the KS is 100k ohms check connection for issues as well as wire for chafing and continuity..
as you know your KS is very close to the distributor so that KS wire must be run correctly or it will pick up the distributor EMI..........
j cAT is offline   Reply With Quote
Old 07-27-2008, 10:57 AM   #17
ukrkoz
ukrkoz's Avatar
ukrkoz Normal reputation
maybe this will be of some help. i know, it's P0325, not 0327, but both codes are virtually identical:
http://www.obd-codes.com/p0325
ukrkoz is offline   Reply With Quote
Old 07-27-2008, 11:07 AM   #18
ukrkoz
ukrkoz's Avatar
just out of curiosity - as i have 2000 5.3V8 on mine - the 99 V6 has a distributor? not ignition modules? i mean, it might as well, i have seen stranger things...
haynes says it has ignition coil and ignition control module, not a distributor. of course, both are high voltage devices, indeed. it's just that there's so much basic difference between distributor and module...
Old 07-27-2008, 02:33 PM   #19
lweford
lweford Normal reputation
j Cat is right, new does not mean that they are good. I failed to mention that when my truck started missing under load I immediately went to the local parts store and bought the cheapest set of plug wires they had. That didn't help my problem. About, 10 labor hours later it was found that the "new" wires were just as bad as the old wires. So I replaced with the premium wires and all was good.
lweford is offline   Reply With Quote
Old 07-27-2008, 02:39 PM   #20
silicon212
AF -Advisor
silicon212's Avatar
silicon212 Normal reputation
Send a message via ICQ to silicon212
The V6 engines STILL use a distributor as it's old Gen-i small block V8 based, specifically it's 6 cylinders of a 350. The Gen III engines (your 5.3) all have individual coil packs.
Anyways, put an OBDII scanner on it and drive it around for a while. Pay attention to the data the scanner is showing. Have a friend drive the truck while you pay attention to the data under acceleration, while coasting and while idling. This will reveal a lot.
Clearing the code on the computer will do nothing but put the computer in 'not ready' mode. Plus, the problem still exists and the light will be back! You won't have to worry about 'not ready' mode unless you are trying to pass a vehicle emissions inspection. If that's the case, you will fail the test hands down. It's best to find the problem, fix it and then go from there. You generally have to have 50 start/stop/drive cycles on the computer after it has been put in 'not ready' mode in order to have it inspected.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
PC Club is dead. Long live PC Club!
silicon212 is offline   Reply With Quote
Old 07-27-2008, 03:14 PM   #21
robertbassin5
robertbassin5 Normal reputation
This is the code that I am getting - DTC P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or
Single Sensor.
robertbassin5 is offline   Reply With Quote
Old 07-27-2008, 03:15 PM   #22
robertbassin5
This what my code is telling me. DTC P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or
Single Sensor
Old 07-27-2008, 04:48 PM   #23
j cAT
the 2000 v6 has a distributor and even an air pump!
Old 07-27-2008, 04:52 PM   #24
j cAT
Single Sensor.
I forgot to mention If they dropped the sensor its n/g....this is a fragile componet...have fun...
Old 07-27-2008, 05:40 PM   #25
robertbassin5
So where should I start?
Old 07-27-2008, 08:18 PM   #26
777stickman
777stickman's Avatar
777stickman Normal reputation
this is were I would start!!
"R57 3CAR" 210 2dr post. 420HP 355 F/I 4sp 3:42 posi. (Dale Earnhardt tribute done by me.)
75 GMC Vandura 3/4 Ton
78 Chevy K5 Blazer
98 Chevy K2500 Suburban LT/7.4
05 Dodge Ram 3500/Cummins (Wifes horse hauler)
777stickman is offline   Reply With Quote
Old 07-28-2008, 03:51 PM   #27
robertbassin5
Hey there I pulled 1 plug out and it is not a platinum plug it's a champion copper plug.
Old 07-29-2008, 12:07 AM   #28
Scrapper
Scrapper Normal reputation
i'd put ngk in in..say missing under load and you replaced plug wires. missing under a load i do a compreson test..
Scrapper is offline   Reply With Quote
Old 07-30-2008, 10:46 PM   #29
robertbassin5
Well here is what is going on with my engine light. First I had code cleared. Second I have replaced the spark plugs, wires, knock sensor, the connector, and used unleaded plus gas. I drove about 100 miles and the code came back. Any ideas? I am stumped and ready to pull my hair out. Just wondering if I should carry it back to the place I had the motor installed.
Old 07-31-2008, 08:50 AM   #30
j cAT
what about the KS wires? did you route them away from spark plug wires and distributor? also what type of gas do you usually use ....?
the possiblity that the computer is bad or the connectors at computer/ecm/pcm......
IT's a long shot but since this KS voltage is very low in amplitude the possibility that they did not secure the ground wires is common ...this will make electronic noise....
Bookmarks
Google
Web AF
