| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
07-07-2008, 10:04 AM | #1 | |
Changing disc brakes - how can you tell if you need new rotors?
Changing disc brakes for the first time - 98 Olds Intrigue.
Brakes are a squeaking and it is time for their annual replacement. Money is tight and I would rather not buy more than I need. So, how can I tell if rotors will last? Also, front brakes are squeaking, how can I tell if rears should also be replaced? |
07-07-2008, 10:36 AM | #2 | |
Nothing scares me anymore
Re: Changing disc brakes - how can you tell if you need new rotors?
New rotors are required when the old ones are too thin and/or rusty (inside where the vents are). A bit of rust is normal; heavy flaking means it's time for new ones).
You need a micrometer or decent machinist's calipers to accurately measure the rotor thickness. The minimum thickness rating is usually stamped on the rotor itself. Every new set of pads MUST also have either new rotors or machined rotors. I would suggest removing the old rotors and taking them to a local mechanic and ask if they can be machined. They can measure them and tell you if they are too thin or rusty or if they can be machined. Around here the cost for machining is about $20 each. You may find new rotors are so cheap that machining does not make much sense. For example, my '97 DeVille's rotors cost me $26 new. Therefore, it did not make sense to drive out of my way to get the old ones machined for $20. The six bucks was not worth the time and effort just to reuse old rotors. As for the rear brakes, pull off the wheels and have a look at the rear pad thickness. If the lining is less than half the thickness of new brake lining, its a good idea to do them. |
07-07-2008, 12:41 PM | #3 | |
SHO No Mo
The O'Reilly Auto Parts chain around here will machine rotors and drums. Last time I had it done it was $11 per rotor. But, yes, for very common cars, new rotors can cost just a little more than the price to machine them. You need to be careful with new rotors though. If they are not stocked properly, they can be warped out of the box.
-Rod |
07-07-2008, 12:53 PM | #4 | |
Professional Ninja Killer
The machinist doing the work will measure them before cutting and advise you one if it can be done or if you need new ones.
I am not of the school of thought that new pads require fresh machining or new rotors. As long as you don't have a pulsation or other big problems, new pads cut rotors pretty hard, especially if you properly bed them in.
Dragging people kicking and screaming into the enlightenment. |
07-07-2008, 02:56 PM | #5 | ||
IMHO using the old rotor surface simply is a bad brake job. I would only consider it in either an emergency or if the car I was repairing was so rare that new rotors were difficult to find (and I did not want to make the old rotors thinner by machining them.) |
07-07-2008, 03:11 PM | #6 | |
AF Premium User
squking pads might be loose in there or built up brake dust...and also like they say it's really cheaper to buy new rotors and i'd put O. E. pads on it they'll last longer...good luck...
07-07-2008, 07:49 PM | #7 | |
Thank you all for responding.
Any recommendations on brands to use or those to stay away from? Anybody know a good site for directions on how to change rotors and pads? |
07-07-2008, 10:11 PM | #8 | |
http://www.oplin.org/databases/proxy...ain.autorefctr
The card number is 123456789 Go to the Cincinatti page. There should be an automotive section somewhere. It loads two different ways for me, depending on how it feels, so you may have to look around a bit to find it. |
07-08-2008, 08:33 AM | #9 | |
I used to believe in cutting rotors with every brake job. On today's cars, I sometimes don't bother since the new pad materials are so aggressive and don't need the break in period that the old pads required. Also anything you take off the rotor decreases the ability to absorb heat. Many rotors will withstand one cut and that's it, after that they're too thin to cut again.
if you want to renew the surface using a DIY method, sand each side of the rotors with an orbital sander and some 60 grit paper. Scuff it up evenly and don't let it dig in. I've done this many times and it never fails me. For pads, especially on the GM FWD cars, use a good brand name pad and not the cheapest one the store carries. Carbon Friction Metallic is a good brand, Bendix also has a couple of good grades of pads. Bob |
07-08-2008, 11:34 AM | #10 | |
This page seems to be hated by so many people, but I list it anyway. I had the opportunity to inspect several rotors with a scanning electron microscope when I had access to the college labs, and its probably the most accurate information I've found on the internet.
The old-schoolers HATE this site with a passion calling it new-age fluff, but I back it. Take it or leave it. http://www.stoptech.com/whitepapers/warped_rotors_myth.htm
07-08-2008, 12:43 PM | #11 | ||
Now I am not certain if the 'warped' or distorted rotor actually causes a pulsing pedal, but sometimes, I have come across a pulse or vibration so severe, with such shaking of the brake pedal that I do not believe a change in friction coefficients is responsible. It must be a physical high spot on the rotor that is quickly forcing the caliper piston in and out of the bore to produce the vibration I feel occasionally through the pedal. I and the old timers may be wrong, but to me it seems the most plausable explanmation for many of the pulsing brake problems. IMHO that site describes the cause many, but not all cases of pulsing brakes. |
07-09-2008, 10:06 AM | #12 | |
In one shop we had, part of our selling program was to SHOW the customers that their pulsating pedal was from badly warped rotors.
We had this clip on dial indicator that we could set up in seconds and show them if they were in doubt. It was something that Ammco (the brake lathe people) was giving away as a promotion. Bob |
07-09-2008, 02:31 PM | #13 | |
I know they warp, I just don't believe that warped rotors cause the pulsation any more than paint color affects ignition timing.
Its easy to jump to the conclusion when you have a pulsating pedal and see runout, but to assume that its the warping that causes it is not a logical step given the knowledge of the metalurgy in the disc. When you machine rotors, not only are you removing the runout, but you're also removing the inclusions in the iron that cause the pulsation; further reinforcing the mistaken idea that warped rotors caused the pulsation in the first place. I've had rotors with no runout exhibit pulsation, and I've had rotors with significant runout that had no pulsation. In all situations, resurfacing the rotors was the answer, but I strongly suggest finding someone with a blanchard grinder to put an OEM type finish on it. The lathe leaves pretty severe grooves like a record. The peaks get very hot under braking and can accellerate pad deposition, which means you'll be back again soon for more machining. I also strongly suggest against any emery cloth or sandpaper. That just drives silicates into the porous casting and makes the problem more likely to come back.
07-09-2008, 10:32 PM | #14 | ||
By posting this you knew you would start a fight!! This is like a Monty Python sketch ("I came here for an argument!!") Go ahead, say something nice about diesels...... I dare ya!! |
07-10-2008, 12:59 AM | #15 | ||
If my rotors don't pulse and haven't worn out, I reuse them. No problems yet. I've never seen the point in machining a rotor, if they're chewed, pitted, warped or dished enough to need it then machining has the potential to create differing thickness which can pulse badly when warm. If they need replaced, I replace them. If they don't then I just reuse them. |
