Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-19-2008, 08:36 PM   #16
ihgrad
ihgrad Normal reputation
Re: 1996 Camry won't turn over.
Replaced the coil- same condition, though it seemed to turn quicker. Stepped on the gas- wouldn't get past choking and coughing and shaking. Any other ideas?
ihgrad is offline   Reply With Quote
Old 05-20-2008, 12:39 AM   #17
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
With the timing marks aligned the rotor is pointing at the number one plug wire in the distributor correct?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
RIP is offline   Reply With Quote
Old 05-20-2008, 10:42 AM   #18
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
I'd find it hard to believe that all of this wouldn't throw a CEL code, so check the OBD for any stored codes. My feeling is to now look closer at the fuel...specifically the fuel line pressure. Too low will cause hard starting and could be a blocked fuel filter (cheap), failing pressure regulator (more $), or failing pump (ouch $$$). Fuel pressure should be 38-44 psi. I'm not sure if '96s have a test port for fuel pressure...they should since it's OBD-II, but I haven't seen one on my '92 unless someone can enlighten me.
You might pull the injectors out too to give them a good cleaning and check for proper operation.
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Old 05-20-2008, 12:30 PM   #19
Brian R.
Resident Chemist
Brian R.'s Avatar
Brian R. Normal reputation
Send a message via Yahoo to Brian R.
No test port. The fuel pressure is checked at the fuel filter output banjo. At this test point, the fuel pressure should be 44-50 psi at idle and engine off with fuel pump operating. When the engine is shut off, the fuel pressure should remain above 21 psi for 5 min.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 05-20-2008, 09:57 PM   #20
ihgrad
Okay, let me add one more dimension to see if this points in one direction or another. When I pull the plugs, they are covered in a black sooty liquid. It is particularly bad in #1 and #2 pistons. These were brand new plugs and they look like they've got 60k miles on them already...
Bookmarks
Google
Web AF
