| Latest | 0 Rplys |
05-11-2008, 05:00 PM | #1 | |
Engine cut off only whene I wait at red light
With my ford probe 94 , 4 2L auto AC .My engine cut off whene I wait at a red light after a few minutes afther a go whene the car temperature is normal .... The oil indicator comme down just before the cut off ....The car restart well.....(someting smell strange). Now whene I wait at a red light I put my car at ``N`` the RPM is higher .....my blug and injector are new and clean......and the oil level is ok....Thank you for your help
07-31-2008, 09:51 AM | #2 | |
Re: Engine cut off only whene I wait at red light
Your alternator could be faulty
Maybe your idle control sensor could be one of the problems? You're saying the car turns itself back on after the engine cuts COMPLETELY, off? |
07-31-2008, 11:15 AM | #3 | |
AF Premium User
i seen this before on my sister can 93 probe..the iac. was bad..
07-31-2008, 12:30 PM | #4 | |
Check your emissions sensors main ones are the idle control and the vent valve from gas tank. look in your auto repair manuel for location and how to test. your vent valve on gas tank are normally closed. if you remove it you can check it by blowing air through them, if air blows through its bad.
08-25-2008, 04:52 PM | #5 | |
the same thing happened to me with one of my probes... try checking the mass air sensor.... the flap sometimes sticks and will kill ur car.... u can see scrape marks on the inside of the housing where it could be hitting
02-06-2009, 02:24 AM | #6 | |
I think I've been having a similar problem. I have a 2.0 with manual transmission. When waiting at red lights the idle will drop really low, sometimes stall. I haven't cleaned my MAF but I put some compression restore additive in when I changed the oil. I noticed an improvement, but I will get some MAF cleaner next time I'm at Autozone.
Thread Tools | |
