Thread Tools Search this Thread
Old 04-18-2008, 02:24 AM   #1
sjelic
sjelic's Avatar
Inbox: Subaru Impreza WRC 2007 Transkit by Reji
You all probably know about Rens transkit. Well here is Reji's effort. It is for Hasegawa kits.
Packed in their usual box, the one I took is Ireland rally 2007
box is almost empty
But you get fair amount of goodies inside.
So basically you get new body, wheels, exhaust, rear wing, central console, hood scoop, discs, clear parts, huge PE set and decals.
I haven't checked what else should be different but this major things are here.
So let's go
Wheels, nice cast this time, a lot of flash but no chips, bubbles etc. Tires are perfect this time, improvement of 100%
Resin parts are a lot nicer then usual Reji stuff, rear wing is made out of two parts, that will make CF job a lot easier.
Now for the clear parts, they are perfect, the best clear parts made by small company I ever saw, such a clean and thin cast.
PE sheet is huge and nicely done by Eduard, nothing more to add.
Decals look nice, print is a bit strange looking, not gloss, but I can't judge it without try.
And now body
Cast is perfect, body is polished to a shine, a lot of flash but that is better then chipped corners.
I will show it all around and since I didn't check it with real car I can't tell what is (if anything is) wrong.
For the end, instructions, a bit more color, not bad, unclear in some segments but you can manage.
Sasa Jelic
SCALEMAKERS
sjelic is offline   Reply With Quote
Old 04-18-2008, 02:54 AM   #2
cham2020
cham2020's Avatar
Send a message via ICQ to cham2020 Send a message via MSN to cham2020 Send a message via Yahoo to cham2020
Re: Inbox: Subaru Impreza WRC 2007 Transkit by Reji
sweet transkit..i am sure it aint cheap eh?
looks like lots of work to do with the body flashes...
Evo Rocks !
cham2020 is offline   Reply With Quote
Old 04-18-2008, 03:47 AM   #3
malscar
malscar's Avatar
Well there goes my credit card again.
malscar is offline   Reply With Quote
Old 04-18-2008, 04:16 AM   #4
manu80
I knew the one made by by renaissance but never heard of this one. looks much cleaner than theit previous kits...
The fluo decals looks very light though...
manu80 is offline   Reply With Quote
Old 04-18-2008, 05:16 AM   #5
sjelic
sjelic's Avatar
could be that the flash killed it a bit, they don't look that light in real.
Sasa Jelic
SCALEMAKERS
Old 04-18-2008, 05:55 AM   #6
Aras
Man,
Where have you bought that kit? I've looked at my web suppliers but it seems they still don't know about this kit.
Cheers,
Aras is offline   Reply With Quote
Old 04-18-2008, 06:02 AM   #7
Sumak
Sumak's Avatar
body is not polished, this is so resin casted....
is from another resin caster, then other REJI kits before....
Sumak is offline   Reply With Quote
Old 04-18-2008, 10:51 AM   #8
sportracer02
sportracer02's Avatar
Hi,
interesting to see this transkit, I just knew about the 2006 transkit from Renaissance. P/E look good, clear parts, too , decals (as you wrote probably due to the flash) look pale.
Concerning the resin you maybe right concerning the dimensions, but the cast is not perfect IMO. Why are the windows closed with rods and fishskin - I don´t see any need for this, every good caster is able to make a "clean" body.
The same with the wheels. If I compare them with Geronimos wheels, I see 2 worlds of casting.
The rear wing comes in 2 parts, you are right, it is easier to decal, but cleaning this upper part ... .
Nearly all other resin parts need lots of cleaning, that isn´t up to date (especially concerning health) an can be avoided (f.e. resin parts of an Impreza transkit could look like this: http://www.renaissance-models.com/1-...e/tk24_264.htm
Micha
Old 04-18-2008, 01:22 PM   #9
Happy Martian
Happy Martian's Avatar
The resin looks nice but I have to admit that I'm a bit confused. Ireland was a tarmac rally, Reji have supplied tarmac rims and tires but the Hasegawa kits that will be donors have got gravel suspension setups. No sign of tarmac suspension parts in this transkit. But from the "Next Products" space on the instructions, a tarmac suspension set will be a separate product ??!! Are they expecting us to buy 2 transkits (body and suspension) each time they make a tarmac transkit (note Monte Carlo is another upcoming kit) ?
Still, as a SWRT fan, I guess I'll be getting this transkit to go alongside the Renaissance one but I'll probably forego the decals and get a second set of Renaissance decals so I can build the only notable success of the last 2 years, Chris Atkinson's '08 Argentinian podium drive.
Happy Martian is offline   Reply With Quote
Old 04-18-2008, 05:58 PM   #10
rallymaster
rallymaster's Avatar
Wow, this TK seems fine though... Still Reji standard but not the worst.
Is there other versions than Ireland as you said "the one I took is Ireland rally 2007" ?
And do you think this can be adapted to the Tamiya kit ?
Body intest me but I would prefer building a Tam kit than a Hasegawa one (moreover I have a spare Tam kit) ?
One thing left, how much do this TK cost ?
Anyway, thanks for this review !
Phil
rallymaster is offline   Reply With Quote
Old 04-19-2008, 12:04 AM   #11
MidMazar
MidMazar's Avatar
Originally Posted by sportracer02
Concerning the resin you maybe right concerning the dimensions, but the cast is not perfect IMO. Why are the windows closed with rods and fishskin - I donīt see any need for this, every good caster is able to make a "clean" body.
I think they did that to support the pillars, but yeh it seems like excess resin. Is that the one from that show someone just posted recently? Also how much is this transkit?
In Progress
Old 04-19-2008, 04:40 AM   #12
malscar
malscar's Avatar
If you look at the last photo of the instructions, it looks like they are also doing Atkos Monte Carlo 08 car.
Old 04-20-2008, 08:00 AM   #13
Sumak
Sumak's Avatar
You are wrong, look on Subarus from Ireland... they have gravel suspension, but bigger brakes and tarmac wheels.....
http://modelforum.upce.cz/forum/down...9841&mode=view
Old 04-20-2008, 08:03 AM   #14
Sumak
Sumak's Avatar
Hasegawa is 2005 version with more acurate rollcage, Tamyia is 2004 Subaru version (but on 2005 Monte)... and as I said, you need tarmac suspension on Ireland version...
Old 04-20-2008, 06:19 PM   #15
Titanicshiloh
Titanicshiloh's Avatar
Irish owned Scoobies all use gravel dampers with the tarmac springs. They usually sit at the same height as the car would on a gravel WRC event. As everyone admitted last November Irish tar is nothing like tar events anywhere else, so much bumpier.
Titanicshiloh is offline   Reply With Quote
Bookmarks
Search this Thread:
