Re: 350 in a 1982 jetta
I was going to put a 350 in a 96 Beretta (bigger than a jetta), and it would barely fit, and that was after doing the following:
-Lowering the brake master cylinder and converting to hydroboost
-Cuting a large portion of the firewall/floorpan out to make room for the transmission
-Relocating the radiator and battery to the rear of the vehicle
-Removing the HVAC system
-Fabricating a frame/suspension to support the weight of the V8 (although you could chop the front end out of an S-10 or similar vehicle in a salvage yard but there's still lots of fabricating to connect it to the unibody of the jetta)
-Since it obviously won't fit in transversely, you need a manual transmission (not enough room for A/T), driveshaft and rear axle out of something RWD (again, probably an S-10, Caprice, etc.)
-The rear has to be reinforced for the axle, and the middle has to be reinforced because FWD cars are designed to be pulled by the front wheels, not pushed by the rear.
-The front wheels are about centered under the engine, which means very little weight on the rear, which means very poor handling if you're accelerating.
I don't want to discourage you from doing this, but you need to know what you're up against. If you end up doing it, I'd love to see some pictures of it.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
