Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 04-03-2008, 06:01 PM   #16
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: P0300 Codes Got Me
Some place in the snapon scanner there is a injector balance test you can do with engine off and with a fuel pressure gauge hooked up to watch how much fuel pressure dropem with injector on a certain amount of time.
On The 02 sensor wiring tsb I posted I had only one blazer that done it.
It had a dead miss on one cylinder.
That I finaly got out by moving the wiring around and switching and unpluging and pluging back up 02 sensors.
If you can find the wiring plug in on the 02 sensor wiring harness you might try unpluging it and see if miss goes away.
Not sure that is your problem but I had one that done it big time.
Drove me ragged trying to find it.
If you want the TSB on it e mail me and I will pdf it to you.
Good luck.
MT
MT
MT-2500 is offline   Reply With Quote
Old 04-03-2008, 06:01 PM   #17
MT-2500
AF - Advisor
MT-2500's Avatar
Good luck.
MT
MT
Old 04-04-2008, 01:24 PM   #18
Gabe25
Gabe25's Avatar
Gabe25 Normal reputation
Thanks MT, Got the serive Bulletin. I tried the fuel balance test with the pressure gauge, but had to stop. My pressure gauge decided to spring a leak. It was old so I'll pick up a new one today and continue. Anyway, Tried spraying carb cleaner around the upper Plenum looking for possible cracks. Still nothing. I drained the gas and replaced it with fresh gas and bleed the fuel lines, and still nothing. This blazer is my sons and I was thinking mybe he bought some bad gas. It was just a thought. Anyway, I'll continue again tonight after work and hope to get her running by this weekend. Will let you know. Thanks again.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Gabe25 is offline   Reply With Quote
Old 04-06-2008, 11:43 PM   #19
Gabe25
Gabe25's Avatar
OK completed the fuel injector balance test with my new fuel pressure gauge and everything tested OK on all the injectors. Now, I remember before reading somewhere that someone was having trouble with there idle and it turned out to be a ground strap from the firewall to the engine. Anybody heard anything like that. This trouble has really got me thinking.
Aloha
Gabe
My Fleet
Old 04-08-2008, 04:43 AM   #20
Gabe25
Gabe25's Avatar
OK, the saga continues. So far I’ve replaced the following:
1. Lower Plenum Gasket Set (Leaking Water)
2. Spark Plugs ( Burning OK)
3. Cap (Little Worn)
4. Rotor (Small Carbon)
5. Wires (Uneven Resistance)
6. Cam Positioning Sensor
7. Coil (Weak Reading)
8. Injector Fuel Regulator (Leaking)
Testing performed:
1. Fuel Pressure.(62psi)
2. Leak Down 20 mins. (59psi)
3. Fuel injector Balance test. (All passed)
4. Fuel Pulse test. (All passed)
5. Cylinder Compression Test (All even)
6. Blue spark at end of plug wire
7. Triple check #1 is TDC
8. Distributor set on #6, Firing order #1.
Trouble is still there. P0300 Code. Multi Cylinder Missfire. Cylinders 4 & 5. I had one more thing to check. O2 Sensor, which I’ll be testing tomorrow. Does any body out there have any ideas. I’m kind of running out of them.
Aloha
Gabe
My Fleet
Old 04-08-2008, 12:02 PM   #21
MT-2500
AF - Advisor
MT-2500's Avatar
Gabe
Just a few things I casn think of to recheck or check.
Did you set the camshaft retard setting on the scanner?
Does scanner show lean fuel trims?
Can you feel a dead miss on the road?
Does pulling no 4 or 5 plug wire affect it any?
Have you double checked the injector plug in?
Liked locked down good and tight?
Is it getting injector pulse on 4 and 5 cylinders?
Does unpluging mass air flow sensor make any difference?
Good luck
And hang in there.
MT
MT
Old 04-08-2008, 03:27 PM   #22
Gabe25
Gabe25's Avatar
MT, Thanks for the ideas. Here is the answer:
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No: When pulled. Only Error code for Mass Flow comes up. Reinstall and error clears
Aloha
Gabe
My Fleet
Old 04-09-2008, 02:28 AM   #23
Gabe25
Gabe25's Avatar
MT, Do you know what the voltage reading should be on the injector pulse? I cleaned the MAF screen wires. They were full of carbon, but no change on misfire. Still searching.
Aloha
Gabe
My Fleet
Old 04-09-2008, 04:07 AM   #24
16th hippy
16th hippy Normal reputation
one side is constant power(battery voltage). not sure if it grounds when vehicle is off/not running.
the other is the ground controlled by PCM/ECM to fire it.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
16th hippy is offline   Reply With Quote
Old 04-09-2008, 09:56 AM   #25
MT-2500
AF - Advisor
MT-2500's Avatar
As 16th said.
One side is 12 volt positive key on.
They trigger off of a ground side pluse.
The PCM controls the ground pulses the ground signal width engine running or cranking.
The pulse width sometimes can be read on scanner.
You will need a lab scope to measure the pulse width.
MT
MT
Old 04-12-2008, 04:30 AM   #26
Gabe25
Gabe25's Avatar
The Final Chapter comes to an end. This has to be one for the books. After going through all of this testing. It comes down to fuel injector 4 & 5 tubes are pluged. Gas was being restricted. I was going to attempt to open them up and clean them out, while removing it from the lower Plenum. Injector tube number one broke. With that, I just said the hell with and picked up a new CPI Unit. Slamed it in and my son is smiling.
MT & 16th. In Hawaii we say Much Mahalo for everything. Which means Thank You Very Much for all of your help. Have a great Weekend. I know I will. Off to the Beach.
Aloha
Gabe
My Fleet
Old 04-12-2008, 09:26 AM   #27
MT-2500
AF - Advisor
MT-2500's Avatar
You are welcome and thanks for posting back how it went.
Glad all is well and fixed.
Enjoy the beach.
We may get some snow today here in Mo. USA.
Good luck
MT
MT
Bookmarks
Google
Web AF
