Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 03-18-2008, 06:11 PM   #16
EGCoupeVtec
EGCoupeVtec Normal reputation
Re: 99 Z24 Cavalier Probs...
Originally Posted by kezia
I believe it's "you're" and "you"
Wat a d*ck...I cant short it out ? I have to write perfect now ? Wat is dis skool ?
EGCoupeVtec is offline   Reply With Quote
Old 03-18-2008, 09:13 PM   #17
JStumpalump150
JStumpalump150 Normal reputation
no but it would be nice to be able to read your posts the first time through and not have to decode it
car domain http://www.cardomain.com/ride/2487171
JStumpalump150 is offline   Reply With Quote
Old 03-18-2008, 09:25 PM   #18
450HP
450HP Normal reputation
JStumpalump150, where did you get your headlights?
Off of that auction site I wonder?
Scott
Wide open till you see God... then brake!
450HP is offline   Reply With Quote
Old 03-18-2008, 09:52 PM   #19
JStumpalump150
wow, lets post the same thing twice!!! its fun and doesnt annoy people.
Old 03-18-2008, 09:55 PM   #20
450HP
Sorry... thought maybe you didn't see it the first time...
Scott
Old 03-19-2008, 09:46 AM   #21
kezia
kezia Normal reputation
Send a message via AIM to kezia
Yay! Let's call girls dicks. Does that even make sense?
kezia is offline   Reply With Quote
Old 03-19-2008, 06:47 PM   #22
Classicrocjunkie
Boosted Grocery Getta!!
Classicrocjunkie's Avatar
Classicrocjunkie Normal reputation
Send a message via AIM to Classicrocjunkie
EGCoupeVtec consider this your first verbal warning, do not come onto these forums and start talking trash about other people cars. If you have nothing constructive or helpful to add in this section, keep your negative degrading comments to yourself.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2004 Pontiac Sunfire Coupe SE Getrag 5 speed
2009 Subaru Impreza WRX 5-door
www.Rdfabs.com
Classicrocjunkie is offline   Reply With Quote
Old 03-20-2008, 02:11 PM   #23
o0kev0o
o0kev0o Normal reputation
OK back to the subject is the security system in it aftermarket?
o0kev0o is offline   Reply With Quote
Old 03-20-2008, 09:10 PM   #24
JStumpalump150
yes it is aftermarket and its a good possibility the security system is at fault because they seem to be the root of a bunch of problems because the car does not like being tricked by aftermarket systems and if even just one part of the system is not working like it should it will trigger tons of stuff including the anti theft because it thinks someone is trying to hot wire the car, when in reality a wire just came loose or something.
i have a remote starter with security system and once in while it will decide to turn the theft light on and not let me turn the car on, i have to go into the stearing column and wiggle wires around because they get pinched and cut off the signal, thats mostly due to the installer not running the wires right thus getting them pinched when i tilt the column up and down. so you may have a problem like this.
Old 03-22-2008, 01:48 PM   #25
EGCoupeVtec
Mah father bought da car at an auction at copart.com wen i was into cavis and sold the 2.2 cavi dat worked just fine then i bought da z24 99 same color as JStumpalump150...Wen i got the car the engine was no good so we had changed it to a 2000 z24 motor...We got the engine running...But all these lights came on like da ones i listed Theft system , check engine light , seatbelt , and a couple more i forgot...Its got alot of electrical problems also..wat happens if i buy another computer wit all the wire harness ?
Old 03-22-2008, 03:14 PM   #26
yhandor
yhandor's Avatar
yhandor Normal reputation
Send a message via MSN to yhandor
Fuck you ricer, Honda is the worst shit you can buy, V-TEC can fuck off, my Z24 eats all those little faggetrockets around here, I laugh at everyone who tries to race me when they are in a Honda, hell for fun, I go smash windows out of Hondas, how's that make you feel? Shove your rice up your ass, remember Cavaliers were built in North America, not JAPAN, you want Honda, move your wannabe chink ass and your JapScrap over the sea and yell about V TEC there, do not come on our forum and talk shit like this, also, learn to type, what are you 12?
yhandor is offline   Reply With Quote
Old 03-22-2008, 03:16 PM   #27
yhandor
yhandor's Avatar
AND as for your problem, check your ground, the one from your negative battery terminal to the body, it may not have a good connection.
Old 03-22-2008, 07:07 PM   #28
Classicrocjunkie
EGcoupeVtec
Reason the car is acting up is because you have a class 1 wiring system from GM, and in 2000 they switched to a class 2 wiring system. The 2.4L motor got some upgrades like no more EGR valve, no more low impedance injectors, different knock sensor, etc. If you want those warning lights to go away, here is what you need to do...
Ok you use everything off your 99 2.4, like injectors, fuel rail, exhaust manifold, EGR. The only major thing you have to do it drill and tap a new hole for the knock sensor. The 2000+ use a different knock sensor (with a smaller hole). You need to use your 99 knock sensor which has a bigger hole.
Also a high impedance computer will run low impednace injectors, but a low impedance computer will not run high impedance injectors. So make sure your using the same injectors from your 99.
......and Rob...... Same warning goes for you about smash mouthing other peoples cars, No exceptions.
www.Rdfabs.com
Old 03-22-2008, 10:37 PM   #29
muff34
muff34 Normal reputation
umm update for ya buddy Honda has had a plant in Alliston Ontario for a while! I think that`s pretty much in your backyard,well ok 1.5 to 2 hours away .......lol. Sorry to burst your bubble
Life Is A Highway ,Enjoy The Ride
muff34 is offline   Reply With Quote
Old 03-23-2008, 01:25 AM   #30
kezia
japscrap...... i'm so stealing that. so i guess i won't be seeing you at the meet saturday..... *so sad*
Bookmarks
Google
Web AF
