| Latest | 0 Rplys |
02-06-2008, 03:12 PM | #1 | |
1993 Buick LeSabre - How do you program the keyless remote
OK I've searched everywhere on the internet, even at the site, programyourremote.com, but no one has any information on programming the keyless remote for a 1993 Buick LeSabre.
My keyless remote has a FCC ID of ABO0303T. I have a 12 pin Data Link Connector under the driver side dash board. Does anyone here have the correct instructions for programming a 1993 Buick LeSabre? (for those with 1996-1999 Buick LeSabre's goto programyourremote.com, they have the correct instructions) George |
02-06-2008, 06:30 PM | #2 | |
AF Moderator Elite
Re: 1993 Buick LeSabre - How to program keyless remote
Fortunately, your car is quite simple to program. Jump the (ALDL) Assembly Line Diagnostic Link. You will find this connector under the driver side dash, but you will have to look through a square cut out in the panel to see the connector, it is recessed behind that panel, almost directly under the steering column.
Jumper pin A to pin G with a fused jumper (3A) Doors will lock and unlock Press the UNLOCK button on the remote Doors should lock and unlock again if you have more remotes press their unlock button (up to 4) remove jumper wire ________|________ [F] [E] [D] [C] [b] [A] [G] [H] [J] [K] [L] [M]
Knowledge can be communicated, but not wisdom! |
02-06-2008, 11:13 PM | #3 | |
Thank you SO MUCH for your very detailed instructions!!!!
I will try this tommarrow! I can hardly wait THANKS AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
02-09-2008, 10:15 AM | #4 | |
Are the instructions the same for a 95 LeSabre remote?
