Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 08-05-2005, 02:05 PM   #16
Data-Man
Data-Man Normal reputation
Thumbs up Re: '99 Lumina Keyless Remote Programming - How To?
Eventually did it...
It took me all together less than 1 minute this time!
WOW...
Well the pictures really helped,, but is I should add anything that would be
the connecter was hiding on top.. and I couldnt see it till I run my hand under that part (under the antenna) and pulled out the cables and the connector.
Anyways just wanted to say thanks...
Data-Man is offline   Reply With Quote
Old 08-19-2005, 08:36 AM   #17
sizemoreracing
sizemoreracing Normal reputation
Re: '98 Lumina Keyless Remote Programming - How To?
I have stipped the entire loom off the main wires in the trunk from speakers all the way to brake light and I cannot find this connector. Is it possible that a base model 1997 Lumina does not have it?
Thanks
shane
sizemoreracing is offline   Reply With Quote
Old 08-19-2005, 01:50 PM   #18
Rubicon1
Rubicon1 Normal reputation
Re: Re: '98 Lumina Keyless Remote Programming - How To?
Thanks
shane
Does your car have power windows and locks? If so, you should have keyless entry. If not, you dont.
Rubicon1 is offline   Reply With Quote
Old 08-19-2005, 02:05 PM   #19
sizemoreracing
It does have pwr windows/locks, but it did not come with keyless remotes when purchased new.
Hmmmmm
I have been trunk diving 3 times already...
Did anyone else find theirs in a WEIRD place?
Old 08-19-2005, 06:06 PM   #20
Rubicon1
Hmmmmm
If you know the vehicle didn't have this option when new, chances are your car don't have the RKE module.
Old 08-22-2005, 10:26 AM   #21
MarkNYC
MarkNYC Normal reputation
After keyless entry reprogram: lights no longer flash
I also lost the lights flashing when doors locked/unlocked. This happened to me after alternator replacement. It is not necessary, but it is handy. Does anyone know how to restore this function?
MarkNYC is offline   Reply With Quote
Old 04-01-2007, 12:20 PM   #22
Schnauzerears
Schnauzerears Normal reputation
I would also like to add that I went to the local Chevy Dealer and they printed off the procedure and gave it to me after I had a battery replaced at the local auto parts store (which is why the Keyless Transmitter needed to be reprogrammed).
The GM manual had a diagram of the ground connector in question that showed a 7-pin connector about 2" wide WHICH DOES NOT EVEN EXIST ON MY 99 LUMINA! The close-up picture http://files.automotiveforums.com/ga...hp?photo=45853 earlier in this thread is what should be in that thing GM calls the "service manual". GM needs to look at who is writing their service manual diagrams and start using real pictures!
Also, can anyone define the Acronyms (abbreviations used) like "RKE", "CKT" and "RCDLR" for sanity's sake?
Thanks and great job in clarifying this mess!
Schnauzerears is offline   Reply With Quote
Old 04-01-2007, 08:42 PM   #23
lastcoupe
lastcoupe Normal reputation
RKE = Remote Keyless Entry
CKT = Circuit as in electrical circuit
RCDLR = Remote Control Door Lock Receiver...This is the module that receives the radio frequency signal from your RKE transmitter (your key fob)
And the 7-pin connector is the electrical connector that plugs into the RCDLR...not the programming connector. I do sometimes find an actual problem with a G.M. service manual, but not very often...and How many pages of information are we talking about? You have to give credit where it is due...those guys do a pretty good job with the manuals as far as I'm concerned, and I use them litterally EVERY DAY. Of course it always helps to know what you are looking at too.
lastcoupe is offline   Reply With Quote
Old 04-06-2007, 07:33 PM   #24
swilkins44
swilkins44 Normal reputation
Will this also work for a 1999 Lumina LS keyless remote also? Thanks!! swilkins44@peoplepc.com
swilkins44 is offline   Reply With Quote
Old 04-07-2007, 12:57 AM   #25
Onblsht
Authorized Vendor
Onblsht's Avatar
Onblsht Normal reputation
Yes, 98 and 99 Lumina use the same remote & instructions.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Onblsht is offline   Reply With Quote
Old 04-07-2007, 09:57 AM   #26
swilkins44
Thanks for the info. It don't look very difficult at all.
Bookmarks
Google
Web AF
