02-29-2004, 12:12 PM
#16
Thanks John
I bought a remote off of Ebay and they sent me "programing instructions" not even close. Thanks John you instructions worked after a few tries it worked. Good job
Todd
03-04-2004, 02:28 PM
#17
I am also having problems with my keyless remote. I have tried all the different ways to program it but when I hold the lock and nlock button nothing happens. I have a 2000 GP
03-04-2004, 06:00 PM
#18
Re: Reprograming keyless entry for an
Did you get the detaide instructions John posted. They worked for me although iI had to try it serveral times.
03-04-2004, 06:03 PM
#19
Re: Reprograming keyless entry for an "02 GP
Here are the instructions I used on my 1998
Transmitter Programming
Important
All transmitters which are to be recognized by the remote control door lock transmitter (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Remove the ignition key from the ignition lock cylinder.
Close all of the doors.
Remove the MALL PGM fuse from the fuse block.
Insert the ignition key into the ignition lock cylinder.
Turn the ignition to ACC. The body control module (BCM) will perform the following in order to identify the type of BCM installed in the vehicle:
Flash the seat belt indicator 1, 2, or 3 times.
Chime 1, 2, or 3 times.
Turn the ignition to OFF, and then back to ACC within 1 second. The BCM may begin to chime and flash diagnostic trouble codes (DTCs). If the BCM has stored any DTCs, refer to Diagnostic System Check - Body Control System in Body Control System.
Open and then close any vehicle door. The BCM will chime in order to confirm that the programming mode has been entered.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for approximately 14 seconds.
Important
After approximately 7 seconds the BCM will chime once to confirm that synchronization has been completed. After approximately 14 seconds the BCM will chime a second time to confirm that the programming has been completed.
Repeat the previous step in order to program each additional transmitter.
Install the MALL PGM fuse into the fuse block.
Operate the functions of each transmitter in order to verify correct system operation
03-08-2004, 10:19 PM
#20
GM remote program
Dear Stinger67L88,
This worked on my 1998 Firebird:
1. Turn off ignition. Remove RADIO fuse (fuse #17 on mine) from fuse block. Cycle the ignition switch from OFF to Run 3 times within 5 seconds until the door locks and the hatch release cycles. Indicating the BCM is in program mode. Leave ignition key in RUN position.
2. Press both LOCK and UNLOCK button on Transmitter for 16 seconds. Door locks will cycle (Lock then UNLOCK) confirming the transmitter has been programmed. Door locks must cycle completely to unlock before proceeding.
3. Repeat step (2) for each additional transmitter to be programmed.
4. Turn off ignition switch, replace fuse #17 or whichever is your radio fuse. Confirm that transmitter functions.
Hope it works for you,
eyeu81
03-17-2004, 01:18 AM
#21
compadability?
i have a remote from our old van that was a olds sil. (4 button) will that be able to be set to a 92 bonneville? if so what would the procedure be , i have also been told that a dealer has to hook up a tool to do it, if some one has feed back to help me, that would be cool.#'s on the remote are gm 10245953 (ab00204t)
03-29-2004, 08:23 AM
#22
Thanks Shortbus for this info!
03-29-2004, 11:24 PM
#23
don't supose that any one has the procedure for a 92 bonne, i have tried so many and had no success,maybe the dealer is the best ,most of what i see is for newer then 92
03-29-2004, 11:47 PM
#24
All hail AF
Re: Re: Reprograming keyless entry for an
Your welcome glad to have been able to help.
03-29-2004, 11:49 PM
#25
All hail AF
Hey sorry I don't have any info on anything older than a 99 you may be able to find a Pontiac dealer that has the service manuals for early model's and get them to copy the procedure and hand it to you. It should be as simple as grounding a wire and pushing a few buttons but I can't tell you for sure since I no longer work at a GM dealer I now work at a Nissan Infiniti dealer. Sorry I would help if I could though.
John
05-03-2004, 04:15 AM
#26
Need helps for my honda 1997
Hi there,
I just bought a used Honda Accord 1997 which equiped with the Chapman security system with keyless entry system installed. But the car does not have any remote transmitter. So I tried the procedures steps listed below to re-program a remote transmitter for my car, somehow the system can learn the remote transmitter, but look like it does not save the new transmitter code in memory. Here is the procedure I did:
1) Open the driver's door.
2) Turn vehicle ignition on.
3) Press and hold the emergency override button.
After 15 seconds, the siren or horn will sound three (3) times. This indicates that the unit has entered the tranmitter programming mode.
4) Release the button.
5) Press the #1 (lock) or ARM button on the remote transmitter to be programmed. The siren or horn will sound once, indicating that the system has "learned" that remote transmitter.
6) Turn the vehicle ignition off to exit the programming mode.
But the problem is that when I Turn the vehicle ignition off or close the driver's door, the system does not respond to the remote transmitter any more. Note that the system responded to the remote transmitter while it is in programming/learn mode.
Thanks in advanced and appreciate for any help !
Phiet69
03-30-2005, 09:37 AM
#27
i need to know instructions on how to program my 2004 grand prix gt keyless entry remote. I can't seem to find the "mall pgm fuse" in my fusebox. Can someone please help.
10-27-2005, 06:32 PM
#28
Re: '02 keyless reprogramming not like '01?
Originally Posted by stiggle
Yes, I'd like to know how to do this.
I tried the 2001 proceedure outlined here, but never get any
response from any remote (I have four) no matter how long
I hold the lock and unlock buttons. All else seems to go
as outlined in the proceedure. What gives?
had the same prob- bought remotes on ebay that were "right ones for my car" and free prog. instr.
pontiac has 3 diff remotes for 98 yo 04 grand prixs
i got #10443537
i needed 10335582
i emailed gmpartsdirect and they sent me the number i needed. try it
08-01-2006, 01:23 PM
#29
Originally Posted by milstream
Does anyone know if this procedure will work on a 2004 GT2?
Ditto that... Looking through the owner's manual and through the blocks themselves, I see no "MALL PGM" fuse... did Pontiac rename or reassign the wiring path to a dfrnt fuse? I DO have a RFA/MOD (remote function activator) fuse.
Any help would be excellent. Thanks!
Paul
New owner of '04 GT2
02-14-2007, 01:50 PM
#30
I have an '04 GT also and can't find the Mall fuse...any ideas?
