Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nonspecific
Old 04-29-2002, 01:57 PM   #76
Tireburner
Tireburner's Avatar
Tireburner
JAWS:
I don't have a book for the 99 Century. This came out of the 98 GM Service manual. Everything I have indicates they are the same.
1) Sit in the driver's seat
2)Remove the ignition key from the ignition lock cylinder
3)Close all the doors
4)Press and hold unlock on the door lock switch (on the door)
5)While holding the door lock switch in the unlock postition, insert and remove the ignition key twice. DO NOT ROTATE THE KEY.. JUST SLIDE IT IN AND BACK OUT.
6)Insert the ignition key the third time, leaving the kin in the ignition cylinder. DO NO TURN KEY
7)Release the door lock switch. You will hear 3 chimes indicating the transmitter programming is active.
8) Press and hold the lock and unlock buttons on the keyless entry remote at the same time (one remote) for 12 seconds. You will hear two chimes. This indicates the transmitter has been programmed.
9)Repeat step (8) for all additional transmitters to be programmed
10) Exit programming by removing the key from the ignition cylinder.
Why isn't common courtesy more common?
Tireburner is offline   Reply With Quote
Old 04-29-2002, 02:05 PM   #77
Tireburner
Tireburner's Avatar
Tireburner
DevinNull :
99 Tahoe:
1) Start with the ignition OFF. hold down the power unlock button on the door panel. While holding the unlock button turn the ignition key ON, OFF, ON, OFF. Release the power unlock switch on the door. The locks will LOCK then UNLOCK
2) Hold down the LOCK and UNLOCK buttons on the remote for 15 seconds. When the vehicle learns the remote, the doors will LOCK then UNLOCK.
3) Repeat step #2 for each additional remote
4) Turn the ignition ON to exit the transmitter programming mode.
5) Verify transmitter functions.
BTW: Stocks in good companies will work as well as Paypal!!!! :frog:
Old 05-06-2002, 12:26 AM   #78
DevinNull
DevinNull
Angry TireBurner RE: '99 Tahoe
I'm not having much luck:-(
I have tried a few times now and I have had a couple other people read the steps provided with now better luck.
Any ideas?
DevinNull is offline   Reply With Quote
Old 05-08-2002, 09:04 AM   #79
Tireburner
Tireburner's Avatar
Tireburner
Programming for 96 Caprice, Impala SS, Roadmaster (B body)
(except wagon)
1) Locate the programming plug. It is behind the left trim panel in the trunk. It is a two pin connector. Both wires should be black/ with white stripe.
2) Put a jumper wire to both pins (single wire, one end to one pin, the other end of the wire to the other pin). The doors should lock then unlock.
3) Press any button on the remote. The locks should lock, then unlock. Press any button on any extra remotes at this time.
4) Remove jumper wire, and test function of remotes.
Old 05-08-2002, 09:12 AM   #80
Tireburner
Tireburner's Avatar
Tireburner
DevinNull :
If this is an old body style, try this. There is a difference between 98, 99, and 00 all are different.
1) At the data link connector. Use fused jumper wire between pin 4 (black wire) and pin 8 (black/white wire) Doors should lock, then unlock
2) Press and hold LOCK and UNLOCK on the transmitter until door locks cycle (about 10 seconds)
3) Repeat step 2 for additional remotes
4) Remove jumper, and test remotes.
Old 05-16-2002, 05:18 PM   #81
BLKNIGHT
BLKNIGHT
Cool
Hi, new here. I just bought a used 98 Chevy Blazer LS 4dr 4wd. Im not sure if it has keyless entry. Is there a way to tell?? I don't have a remote but will buy one if it has it. Thanks for any help!
BLKNIGHT is offline   Reply With Quote
Old 05-17-2002, 08:27 AM   #82
Tireburner
Tireburner's Avatar
Tireburner
BLKNIGHT:
There is a Body Control Module located to the right (pass side) of the gas pedal. The BCM has 3 plugs (1) Brown, (1) Light Blue, (1) Purple.
The plugs face the drivers side of the vehicle.
In the Brown plug pin #B4 if there is an orange wire, it should have the keyless option.
Pin B4 the wire is orange. Pin B3 is a Red/wt wire, and pin B5 has no wire.
another option would be to call the parts dept of your local GM dealer, and give them the VIN #, they can plug that into the computer and tell you if it had keyless.
Old 05-17-2002, 02:46 PM   #83
BLKNIGHT
BLKNIGHT
Cool
Tireburner: Thanks for the info. I'll check it out!
Old 05-19-2002, 01:59 AM   #84
birchrj
birchrj
Question
Tireburner, you are da man! I wondered if the instructions you gave blknight is the same for two vehicles I have, a '95 Olds 88 LS and a '95 Suburban LS. I think both have security systems in them, but I got both without remotes. If I can determine that they came with them, I will definitly be looking for one or two for each. 6 kids, including a 10 month old, Mama would really like to unlock the doors from a distance! Do you have any that you would like to part with, at a reasonable cost?
birchrj is offline   Reply With Quote
Old 05-24-2002, 10:11 PM   #85
MaNKoRn427
MaNKoRn427
Keyless Remotes Reprograming
I need help with reprograming remote entry remotes for my '95 Mercury Cougar XR7. It has a dealer added option alarm system labeled " Ford Security System ." I got 2 (4 button) remotes that are from a car a few years newer. The alarm system features trunk release, courtesy lamps, lock and unlock, siren, and a shock senser if this info helps any.
MaNKoRn427 is offline   Reply With Quote
Old 05-28-2002, 09:35 AM   #86
Tireburner
Tireburner's Avatar
Tireburner
MaNKoRn427:
That piece was manufactured by Code Alarm (recently purchased by Audiovox) The only phone # I have for them is:
800-468-3241
Hopefuly they can assist you in programming.
Old 05-28-2002, 09:58 AM   #87
Tireburner
Tireburner's Avatar
Tireburner
Programming for 00 S Blazer
1) With drivers door closed, hold down the power unlock button on the door panel
2) Turn the ignition ON, off, on, off
3)Release the power unlock switch on the door panel
The keyless receiver will respond by locking, then unlocking the doors
4) Hold down LOCK and UNLOCK on each remote one at a time until doors lock then unlock.
5) Turn on the ignition switch to exit programming.
Old 06-01-2002, 03:41 AM   #88
knavenet
knavenet
Unhappy
Hi there. Wow, first let me say this is a great board. Seems like I might be able to find the secret to eternal life if I keep looking long enough on here!
However right now I need to ask for help.
I need to find out how to reprogram for a 2002 Malibu.
I was hoping the Door Unlock, ignition on off trick would work. But if that's it I must be having problems.
Any help will be greatly appriciated.
-Thanks
I hate it when ninjas break into
my backyard and steal all my gold!
knavenet is offline   Reply With Quote
Old 06-01-2002, 06:59 PM   #89
MaNKoRn427
MaNKoRn427
Tireburner
I bought a remote from the dealer that i bought my car from used. I have trouble reprograming it. The system installed is not wanting to cooperate with me. I think it is not functioning properly. It is a Ford Vehicle Security System 600 Plus. I have no wiring diagrams to see how if is wired properly. Oh well i'll give the phone number a try and i have a number with the remote to call, too, 1-800-FORD-KEY.
Old 06-03-2002, 09:16 AM   #90
tonysch
tonysch
2002 Chevy Tahoe Keyless entry
I was hoping someone could tell me how to program the keyless entry for my 2002 Tahoe.
Thank you
Tony
tonysch is offline   Reply With Quote
Bookmarks
Google
Web AF
