Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nonspecific
Old 01-11-2002, 05:17 PM   #16
audiotech
audiotech
hey guys , I am new here . I was wondering if someone could help me figure out how to program a keyless remote for a 95 Blazer . I have done one before on a T/A I had , but the wire configuration in the diagnostic terminal is different here , there are only 6 wires in the back of it . Thanks !
audiotech is offline   Reply With Quote
Old 01-14-2002, 09:04 AM   #17
Tireburner
Tireburner's Avatar
Tireburner
My 95 Book doesn't show programming, so I went to the 96 book. As near as I can tell the vehicles are the same I'm not showing a change until 98, so from 94-97 this info should be correct.
1) Ground terminal No. 8(black/white wire) of Data Link Connector (DLC) Located under lower left side of dash. Reciever will respond by locking and unlocking doors within 2 seconds. Press any button of first transmitter to be programmed. Control module will respond by locking/unlocking all doors and activationg liftgate release
2) Press any button of second transmitter to be programmed. Control module will again respond by locking/unlocking all doors and activating hatch release. Remove ground from DLC terminal 8. Transmitter operation can then be verified. Attempt all functions with remote.
Tireburner is offline   Reply With Quote
Old 01-15-2002, 08:35 AM   #18
Tireburner
Tireburner's Avatar
Tireburner
Originally posted by rjones2001
Now the pontiac remote for some reason does not program. im thinking its because it may be broken (have tried new batteries) or because the DOC/MDC appear different from the buick. Now a dealership in my area said the FCC ID for the Pontiac should work for my car. The specifications on the back of this remote are GM Part Number (25602667.68.69); Model/FCC ID: (ABOO3O3T, DOC/MDC: 218 K1033); and made by United Technologies Automotive.
I found two remotes identical to each other. I believe they are from a Suburban approx. 95 year.
GM P/N 15955702
DOC/MDC 218 K1035
FCC ID ABO 01047
I don't have X reference guides on these remotes to see what they are compatible with, but most GM vehicles from that time period used TRW systems.
The ones I have have "Lock" on the left, "Unlock" on the right, and "Rear" on the bottom center.
If you would like to send me your address via e-mail, I will mail one or both to you and you can see if they will program.
Jack@directed.com
Old 01-18-2002, 11:13 AM   #19
zippy6000
zippy6000
Question Need help with a 99 Tahoe
You have some great tips posted here. I want to thank you very much!! I have a '99 Tahoe that has remote keyless entry and remote start. The only problem with this is that they are on two different controllers. I was wondering if the stock keyless entry is smart enough to be programmed to accept a new transmitter that can do all of the above.
Any ideas? I have a transmitter from crimestopper that can do both.
Please let me know.
zippy6000 is offline   Reply With Quote
Old 01-18-2002, 11:20 AM   #20
Tireburner
Tireburner's Avatar
Tireburner
zippy6000
Your Crimestopper, provided it has the outputs to do door locks, will do your keyless and remote start. But, you can not program the factory remote to the Crimestopper unit.
They two units operate off of different frequencies. Sorry.
Old 01-18-2002, 11:26 AM   #21
zippy6000
zippy6000
re: Need help with a 99 Tahoe
Thanks for the quick reply. The Crimestopper remote is from a different car. I just got the Tahoe and I don't know what remote start system it has in it.
So is there anyway at all that I could get it down to one remote. Except for installing a new remote start/keyless entry combo and bypassing everything that is in it now?
Old 01-18-2002, 11:31 AM   #22
Tireburner
Tireburner's Avatar
Tireburner
Re: re: Need help with a 99 Tahoe
Unfortunately, that would be your only option. The thing to watch out for is if the Crimestopper is an older unit, putting a new Crimestopper in, they may not be cross programmable.
Old 01-25-2002, 11:16 AM   #23
Tireburner
Tireburner's Avatar
Tireburner
Sorry it took so long, but I finally found a GM tech that would help.
Drop the underdash. there are 3 -7mm holding it up. Right next to the parking brake mounted on the underdash pane is a module. This is you keyless entry module.
Ground the black wire with the white stripe wire
The doors will lock then unlock, and the hatch should pop
press lock on each remote one at a time
The doors should lock/ unlock to confirm the remote(s)
Remove ground from black/white wire.
Hope that helps!
Why isn't common courtesy more common?
Old 01-26-2002, 11:52 AM   #24
audiotech
audiotech
Thumbs up
Hi Tireburner,
I tried the module procedure on my 95 Blazer and it worked like a charm . Just a thank you note , you certainly went out of your way to help me out , and I really appreciate it .
Thanks again.
Old 02-04-2002, 12:12 PM   #25
Tireburner
Tireburner's Avatar
Tireburner
Hi Tireburner,
Thanks again.
Happy to be of service!!!
Old 02-05-2002, 12:24 PM   #26
Brokenbone
Brokenbone
Question Prgrammng '97 Chevy Suburban keyless
Appreciate all the tips provided for this thread especially grateful to Tireburner for the manual excerpts.
For our vehicle, '97 Chevy Suburban, I attempted programming a transmitter from the recommendations provided by Tireburner on the '98 Blazer but wasn't successful. I researched Tireburner's recommendation for the '95 Blazer; after looking under the dash near the parking brake, I couldn't identify the keyless entry module or the black and striped wires noted.
Is the '95 Blazer procedure the right direction to take? If so, could the keyless entry module be in a different location than the Blazer and/or are there any distinguishable marks that may help a shadetree dummy like myself identify this module? Thanks for your time!
Brokenbone is offline   Reply With Quote
Old 02-05-2002, 12:38 PM   #27
Tireburner
Tireburner's Avatar
Tireburner
Re: Prgrammng '97 Chevy Suburban keyless
Provided you have a factory system the following proceedure will work.
1)Ground terminal #8 (black/white wire)of Data Link connector (DLC) Receiver willl respond by locking / unlocking all doors within 2 seconds. Press and hold LOCK and UNLOCK buttons on the remote simeltaneously on first transmitter until locks cycle (lock then unlock)
2) Press and hold LOCK and UNLOCK buttons simeltaneously on second transmitter until the locks cycle
Remove ground from black white wire pin # 8 at DLC
Transmitter function can now be verified..
DLC is located under drivers side of dash, bolted directly to the bottom of the dash panel
Hope this helps!
Old 02-06-2002, 11:17 AM   #28
Brokenbone
Brokenbone
Thumbs up RE: '97 Suburban remote
Tireburner: Thanks for the information on programming our keyless remotes for the '97 Suburban. The procedures listed went exactly as you described. Your expertise and willingness to share it is certainly appreciated.
Brokenbone
Old 02-06-2002, 11:24 AM   #29
Tireburner
Tireburner's Avatar
Tireburner
Brokenbone:
Thank You! Happy that I could be of assistance!
Old 02-08-2002, 11:04 AM   #30
gary7622
gary7622
Question Programing 99 Buick Park Ave
I have tried all the methods listed and none of them work on my car. Does anyone have the info on this car? The remote is a GM/UTA FCC# K0BUT1BT.
gary7622 is offline   Reply With Quote
Bookmarks
Google
Web AF
