Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 12-02-2007, 02:23 PM   #1
wesschar
wesschar Normal reputation
Question moisture
My husband has a 2000 Astro Van AWD that will not start if it rains or gets any moisture. Everything has been changed on the van. We just had new oxygen sensors replaced 2 days ago...He was told that was the problem...Not so cuz it is not starting now.....
This is all new to me so I need some help - Please...Thank you
as per him! new distrinutor cap, new wires, new plugs
wesschar is offline   Reply With Quote
Old 12-02-2007, 06:54 PM   #2
jwjoerugby
jwjoerugby Normal reputation
Re: moisture
I had the same problem, as you can read if you check a number of posts back, i replaced the distributor cap, rotor, ignition wires and plugs and it seemed to take care of the rain prob (but i had more after that).
But since you have already done that i was told that it could also be the ignition coil, or the distributor itself. Good luck anyways.
jwjoerugby is offline   Reply With Quote
Old 12-02-2007, 07:21 PM   #3
wesschar
Re: moisture
thank you I will tell my husband and check the past posts
Old 12-03-2007, 05:24 PM   #4
rgmc
rgmc Normal reputation
Re: moisture
Hi
Had my 98 die about 50 miles into a 400 mile trip
Then it started fine.
Then it wouldn't start the next time it rained
Pull the engine cover and look for a light show when starting in the dark
ignition coils tend to short out to the engine
good luck
rgmc
rgmc is offline   Reply With Quote
Old 12-03-2007, 06:08 PM   #5
wesschar
Re: moisture
thank you rgmc
i'll give him this info
Old 09-09-2009, 11:03 PM   #6
brohamed
brohamed Normal reputation
Re: moisture
i have had several astro/safari they all get moisture in the distibutor cap check the vent hole inside distributor cap make sure it is clear later models come with a screen inside the hole remove it per: chevrolet update doesnt allow proper air flow even if cap is new first rain will do it
brohamed is offline   Reply With Quote
Old 10-25-2009, 03:17 PM   #7
harryevan
harryevan Normal reputation
Re: moisture
I also had (I hope its gone) a problem with moisture - my 2000 wouldn't start for 3 days after the last storm. So I swapped out the Accell cap and rotor for the AC/DELCO parts (still have a NAPA cap, but the pros on the list nixxed that, so I went to AC/DELCO). I'm waiting for the next storm (today or tomorrow). In the meantime, There's a few things:
The Accell cap and rotor have a fine light green powder in the areas above the rotor cap.
Looking down into the cap, all the posts have quite a bit of arc residue on the right-hand side of each post, not in the center. Is that indication of a timing problem - firing adavanced?
I found no indication of Brohamed's vent hole on the Accell cap, and I didn't really notice one on the AC/DELCO.
Should I expect problems after he next storm?
harryevan
2000 Astro AWD LT
162000
had it two years
harryevan is offline   Reply With Quote
Old 10-25-2009, 10:58 PM   #8
Leeann94astro
Leeann94astro Normal reputation
Re: moisture
The vent hole isn't in the distributor cap; it's in the distributor itself. GM put a screen in it to keep out debris, but the screen holes were too small to allow moisture to escape. They put out a TSB saying to remove the screen.
1993 Olds Bravada 4.3L CPI
1993 Chevy Astro EXT AWD 4.3L CPI (not a '94...oops)
Leeann94astro is offline   Reply With Quote
Old 10-26-2009, 07:58 PM   #9
brohamed
Re: moisture
as leeann94astro stated the vent hole is in the distibutor itself and not the cap
Bookmarks
Google
Web AF
