Originally Posted by mallenfam
Status (time for a final diagnosis?):
1) Jumping 12V to the prime wire does not get the pump running.
2) Measuring votage at the prime wire is ~0.300 V before turning the key to ON, then the voltage jumps around (momentarily ~1.0V and maybe 10V for a millisecond, but nothing steady or substantial) before the 2-second relay kicks off. The relay(s) located in the glovebox relay center do click before and after the 2-second period (I could not identify a relay box in the engine compartment, just a big flat ECM by the right fender?).
3) Does the relay clicking confirm that power is successfully flowing from the ignition switch through the fuse panel before reaching the relay?
4) The pump never showed signs of dying when the vehicle was running. Only now and one day a couple of weeks ago when going to start it and the pump simply doesn't prime for starting. Running the engine for a few seconds while spraying in starting fluid did not get the pump running again.
5) Checking power at the pump connections means I have to drop the tank right? I am going to be so bummed if I pay $300+ for a pump and that's not the cause (OK, I'll quit whining).
6) Do these symptoms confirm a dead pump?
Thanks for your shared experience and guidance!
Sorry about telling you it was in the under hood box.
Yes the wiring diagram does show the fuel pump relay in IP panel box but the one on left side.
But relay locater says it is behind glove box.
Feel the relay and check for a click on on the 1-2 second key on prime up.
I also like to check for good spark to spark plugs to when no start.
Look at fuel pump relay diagram.
You will see the prime connector wire is not a direct hook up to the fuel pump gray power feed wire,
Find the gray wire to fuel pump and jumper it for a good pump test.
There should be a plug in connector usually 4 wire behind or in front of fuel tank that is a good place to check for power to fuel pump and for ground.
If you have 12 volts on the gray wire there and ground on the black wire and fuel pump does not run then it is time to drop tank and go for a fuel pump.
MT
