Go Back   Automotive Forums .com Car Chat > Ford > ZX2
Old 06-29-2007, 05:03 PM   #1
wrems
‘98 ZX2 Error code P0113 IAT Sensor
Check engine light came on and gave me error code P0113 indicating IAT sensor. So I pulled the negative battery cable and replaced the sensor. The problem is that the check engine light still comes on after the first re-start and the code still reads P0113. Any ideas?
wrems is offline   Reply With Quote
Old 08-05-2007, 10:15 PM   #2
Markb873
Re: ‘98 ZX2 Error code P0113 IAT Sensor
I have seen a loose MAF connecter or "bad" MAF trip that code.
-Mark
Markb873 is offline   Reply With Quote
Old 02-04-2009, 12:23 AM   #3
98mtxzx2
you dont even need the iat
theres a mod called the pots mod that eliminates it anyway
you will see better power with out it
98mtxzx2 is offline   Reply With Quote
Old 02-04-2009, 12:30 AM   #4
'97ventureowner
'97ventureowner's Avatar
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines:
POSTING IN CLOSED OR OUTDATED THREADS:
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
'97ventureowner is offline   Reply With Quote
