Originally Posted by laxman21
I'll OHM it tonight.
Are you saying that if the low side has 65 when the compressor is off, it's a bad compressor?
What OHM reading should I get on the switch.
Do I have to drain the system to replace the switch?
No on the 65 low side comp off.
But the low side switch should be making contact threw it or show OHM"s reading for contact with 65 lbs.
The low side switch turns off or opens contact at around 28 lbs or lower.
Over 28 lbs it makes contact and under 28 lbs it opens up/no contact.
The switch will just screw off and on. No drain No problem changing it.
