Originally Posted by chevy_lifted_4x4
I took off the cat and muffler and that is all cleared out. The MAP has good vaccum to it. The codes are still coming up. # 33 says low vac to MAP and 42 says ECM has seen an open or grounded EST or bypass circuit. What does this mean?
You need to get a good repair manual and go threw the repair flow chart for code 42.
Could be wiring or est module or bad pcm.
On the map sensor code check wiring and actual engine vacuum and vacuum to map sensor.
What is the engine vacuum readings at idle and at 2000 rpm?
MT
