Originally Posted by need_a_new_truck
On the 98's there is a marking on the distributor cap (number 6) that the rotor should point to when the #1 cylinder is top dead center of compression stroke. Then I think the cam and crankshaft position sensors adjust the timing automatically(No timing light needed). So if you adjust the dist cap a little from the marking on the cap, the sensors should compensate for that adjustment.
Here is the markings on dist to set it for installation.
http://files.automotiveforums.com/ga...hp?photo=51302
But the PCM/VCM will not adjust anything if you turn the dist.
The dist only has a camshaft sensor in it to let the computer know where the camshaft retard setting is.
In - or + degrees.
The camshaft retard setting set as close to 0 - or + degrees centers the dist rotor to fire dead on or straight at the plug wire terminal.
If it is to far off you will get a code for it being off and if to far off you may get miss fires.
Also if it is to far off you will get a large spark gap which can result in high voltage spark that can damage plugs and engine from to hot of spark.
MT
