I have the Flex-a-Lite Black Magic 150 electric fan installed on my X and it runs just a tad cooler than normal in everyday driving, I can let the truck idle with the air on all day long and it runs below half. Now I have had a cooling problem since day one with my truck that Nissan can't seem to fix, I thought this would help and while it runs cooler day to day my truck ran hot a few times at GOX. After talking with another X owner at GOX that has had the same exact symptoms I believe the thermostat is the problem, I just can't believe Nissan would overlook this simple change. Watching my temp guage it makes sense, when running hot it will then drop 3 needle widths all at once then do this again then again until it is running normal again....not a smooth progression of cooling. I am going to change the thermostat and hopefully this clears up the problem, I doubt Nissan would touch the truck with the electric fan now so I will take care of it myself...anyone know of a hi-flow thermostat made for Nissan's?
BTW: I gained a good bit of power from the electric fan, on the way to my shop is mostly hills forcing me to downshift to climb them...now I can pass people in 5th on all but one hill now.
Hopefully tomorrow I will replace it and that fixes the problem....now I never even looked but I thought I heard that the thermostat placement on the 3.3L motor sucks. Lance are you part of MAXC?
Yep, actually a founding member along with Philosopher(Mr T), Synchro and Pikachu. We got to get together for some wheeling soon, we are only about an hour from each other.
Yeah, sounds like a PITA Todd. Here's the ESM description...
1. Drain engine coolant from drain plugs on radiator.
2. Remove radiator hoses (upper and lower) and fan shroud.
3. Remove drive belts.
4. Remove pulley bracket. (the black one across the upper front of engine - Brent)
5. Remove water inlet and thermostat assembly.
