| Latest | 0 Rplys |
11-22-2006, 10:00 PM | #1 | |
Leaf spring replacement?
I have a '96 Cherokee 4x4 and the leaf springs are pretty much shot. I would like to know of any reputable brand that would be a good replacement to the ones on right now. Currently, the shot ones are the stock springs.
Also, any idea on how difficult the job to do it would be? I am very capable but want to know if I could do the job with a guy or two on a Saturday? Any suggestions? I heard that there is something about the bushing to the frames always being stuck and you need to cut through them to remove? Please advise. |
11-22-2006, 10:30 PM | #2 | ||
Re: Leaf spring replacement?
Removing and replacing the springs isnt a big job unless you run into rust issues. A common problem is for the spring eye bolts to rust to the nuts that are welded to the inside of the frame rails. If that happens and you break the welds on the nuts, you are in for a bit of work, cutting through the floor panels to access the inside of the frame. Ive never had to do this but have read plenty about it. I can probably come up with a write up if you need it. Dont forget, you will need new u bolts also. Those can be almost as expensive as the springs. |
11-23-2006, 11:10 AM | #3 | |
Depends on where you live...salt on the road equals rust and stuck bolts.
Out here in Cali..my screws are on tight but removable. My u-bolts were reusable. Stiffness and lift are another consideration. Search this forum, ....others have used JC Whitney and quatratec. The quatratec HD has a slight lift 1 inch or so. http://www.quadratec.com/products/56010_11.htm If you want lifted springs...they are a lot of aftermarket to choose from. You can make some also, called a bastard pack. A common one is made from S-10 springs cut shorter. You use the original XJ top spring and put the S-10 pack under it (by cutting the eyes off and making the top leaf shorter). Some folks use Datkota truck springs. Other folks buy another XJ spring set and cut off the eyes and add it below. All of these should give you a lift. Anyway you can design your own. You can also do an AAL(add A leaf)....use the long one IMO...you won't have to remove the spring at all in this case and it might be the cheapest senario. Careful...use C-clamps if you pull the center pin and unwrap the leafs. There are writeups about this on the web. |
11-23-2006, 10:28 PM | #4 | ||
11-23-2006, 11:29 PM | #5 | |
You do have a good point about the U-bolts...and I had not heard that before ...and I did reuse them for now.
I guess all the brand vehicles that I worked on professionally...well I never did u-bolts. |
11-24-2006, 06:42 AM | #6 | |
There was or is a write up on swapping out XJ springs anda replacing with a spring pack from a Dakota on NAXJA....just went ther and searched....evidently they are having some techinal problems at this time...I'll try later and see if I can find the article and post a link to the write up
Found it.......Lottsa pics and info here.......................... http://www.naxja.org/forum/showthrea...Leaf+Pack+Swap
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN Last edited by Stick89; 11-24-2006 at 12:32 PM. |
11-26-2006, 07:12 PM | #7 | |
Thanks for all the info. You guys rock! Yeah, I live in MI so those the U-bolts must be rusted on.
-Joe |
11-27-2006, 06:35 AM | #8 | |
Caution: Monkeys bite!
You may want to also consider having the existing springs re-arced and adding a leaf; I've had that done to a couple of older cars and it works great, and is pretty cost effective. The places I've had it done usually have "spring and alignment" in the name.
Ours: 2020 Jeep Wrangler 2.0, 53k 2013 Toyota FJ Cruiser, 84k Kids: 2005 Honda CRV, 228k |
11-27-2006, 11:17 AM | #9 | |
12-05-2006, 08:03 AM | #10 | |
I would like to know the opinion on the ride if I were to go with the replacement part as shown below:
http://www.quadratec.com/products/56010_11.htm#details I'm assuming that this set-up would be more beefy than the stock OEM part. Would the lift be any higher? How much of a lift to the leaf springs would be allowable before I have to start thinking about changing the shocks and this like that? Sorry about all the questions but I am not knowledgeable in suspensions for XJ. Thanks. |
12-05-2006, 10:12 AM | #11 | |
Two of the recomendations are worth looking into first:
*Fred's suggestion...rearcing them at a spring shop. *add a leaf (AAL) http://www.jcwhitney.com/autoparts/V...003426/c-10101 I like the looks of the Warrior at the bottom. The Rough Country is only $40. __________________________________________________ ______________ Your question on the... http://www.quadratec.com/products/56010_11.htm#details Answer: Expensive...but higher quality job. You need two... plus the bushings. The same shocks will work...maybe 1 inch higher (??).. *Here is some others that people have used: http://www.jcwhitney.com/autoparts/P...003427/c-10101 |
12-06-2006, 12:56 PM | #12 | |
The Quandratec in question as you have recommended is a 7" arch and they also have a 5" arc. I asked Quadratec about this. As I said, I really want to utilize the towing package I put on so would it be advisable to put on the 7" arch or the 5" arc. It's hard for me to visualize how it would look in my XJ because the leaf springs are really flat right now. Quadratec says that there is a 2" deflection from the rear end weight and I just want to make sure that I won't have to do any more mods. after the leafs (7") are installed. Should hI have any other problems? Will this be best for towing?
Thanks for your help so far. |
12-06-2006, 01:34 PM | #13 | |
Here is a couple of old posts for you:
http://www.automotiveforums.com/vbul...d.php?t=550965 The factory "up county" spring has a 1" lift. http://www.jeepforum.com/forum/showthread.php?t=127765 This link has all factory numbers: http://www.rigidsteel.com/y131pC3tIGk0.html The stock leaf spring is almost flat. If it was mine and I did not want a lift...I would look into the helpers. Or the spring shop for advice. |
12-06-2006, 10:06 PM | #14 | ||
"That's mighty bold talk for a one-eyed fat man." |
12-06-2006, 11:49 PM | #15 | |
Alright..I am going with Irish...
New springs...heavy duty are the way to go.... Cost effective...cause you will be happier with new stuff. |
