| Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here. |
11-01-2006, 09:15 PM
#16
Re: Rockers?
ok so .480 intake and .490 for exhaust.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
11-01-2006, 09:16 PM
#17
Re: Rockers?
but i will be on stock heads. i don't want to put new heads on a 305. So will the 1.6 rockers work with my LT1 cam?
11-01-2006, 09:17 PM
#18
Most Seniorest Mod EVER!
Re: Rockers?
The duration is what creates lope and such but the lift numbers aren't bad with some 1.6 rockers. You also have to remember that the head and intake of a car doesn't change even though you increase the lift. So you don't want to go too radical or the rest of the engine won't efficiently keep up with the vaccuum demand.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
11-01-2006, 09:18 PM
#19
Re: Rockers?
Yes, it will work as long as you have adequate springs (which you stated you do)
11-01-2006, 09:19 PM
#20
Re: Rockers?
Yes, the rockers should work. That's actually one of the bolt-ons for the LT1 is 1.6 rr to increase lift. They apparently advertise 15-20 hp gain for just swapping the rockers on an LT1. I don't know much about the 305's, but they should work, but will you have to modify the valve covers so they don't hit?
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
New Toy
2009 Kawasaki Ninja 500R
11-01-2006, 09:21 PM
#21
Re: Rockers?
sweet, so they won't hit the stock heads like nate said? if not i will do that with a new intake mainifold and put my headders on and a good tune should be some good numbers then.
11-01-2006, 09:22 PM
#22
Re: Rockers?
so what will i have to do with the valve covers? do they sell some kind of spacer for them?
11-01-2006, 09:25 PM
#23
Re: Rockers?
Not completely sure on that one. You may not even have to worry about it. But if they do hit, you could just buy some deeper valve covers that look all nice and respectable-like. But I know they do sell something like a spacer that will raise the cover a tad for adaquate clearance if you need it.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
New Toy
11-01-2006, 09:27 PM
#24
Re: Rockers?
I believe the max lift for stock swirl port L03 head is right at .480 so that would be pushing it.
You think those number are low, the cam he has now is something like 178/194 @ .050, .350"/.385". Big reason why L03 have low output.
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
11-01-2006, 09:29 PM
#25
Re: Rockers?
Ahh...that factory cam spec is pathetic. I'm amazed it actually works.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
New Toy
#26
Re: Rockers?
where can i get the spacers at? like jegs or something?
11-01-2006, 09:34 PM
#27
Re: Rockers?
I dunno, check summit or something. It would help if someone knew the actual name of the part.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
New Toy
#28
Re: Rockers?
You will need to remove some material from inside the cover to keep the rockers from hitting the top or you could just buy some 93 - 96 Vette valve covers which are already clearanced for 1.6's.
11-01-2006, 09:38 PM
#29
Re: Rockers?
Damn, I was just gonna say that.
In GM High Tech Performance mag, they home-built an LS1 383 and they had valve cover clearance problems and they just scraped some of the shit from under the valve cover off for clearance.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
New Toy
11-01-2006, 09:49 PM
#30
Re: Rockers?
they also make a "tall" style valve cover exactly for this. Aftermarket only.
The name says it all there taller to clear 1.6 rockers. I have some chrome ones from holley paid 80$ for a pair, not that bad.
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
