Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-28-2006, 02:03 PM   #1
l_eclipse_l
l_eclipse_l's Avatar
Power window stopped working...where's the fuse?
Alright guys I need help. My passenger power window stopped working a few weeks ago. The driver side works just fine. The power locks work for both doors. I tried the window switch for the passenger side from both doors, neither seems to have power.
The window dosn't budge, so this makes me believe it's an electrical issue. I tried looking for any fuses that regard to power windows, and I couldn't find any on the big cluster in the engine bay nor in the little cluster under the dash on the drivers side. The sunroof fuse was about as close as I got, which works just fine. Anybody know where this fuse is?
Yes, I do have a Chilton's manual but I can't find it right now.
I have tore off the door panel to see if anything was blatantly not plugged in, and I didn't see anything. I did find a broken off screw that fell out of the door panel after I took it off, but I can't find where it goes and I don't think a tiny little screw is my problem here.
I do not have a multi-meter so I can't test the wires, but like I said everything else works pertaining to power like locks, etc. The car is a '99...I sure hope window motors and stuff like that arn't going out already.
Any suggestions?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
l_eclipse_l is offline   Reply With Quote
Old 10-29-2006, 12:11 AM   #2
xavier3jr
xavier3jr's Avatar
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Re: Power window stopped working...where's the fuse?
the power window fuse is one of the big 30 amp fuses if im not mistaken there green. and if the fuse was blown there neither would work if the switch goes bad on the pasenger side then the drive side wont roll it down either because it will be in a incomplete circuit
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
xavier3jr is offline   Reply With Quote
Old 10-29-2006, 07:25 PM   #3
l_eclipse_l
Thanks for the help man. So, I can rule out a blown fuse then.
Anybody else know of why it wouldn't work besides a blown window motor?
'92 3000gt SL
Zoom Stage 1 Clutch
Old 10-29-2006, 07:50 PM   #4
gthompson97
gthompson97's Avatar
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
The switch could either be bad or the motor. The switch doesn't have to work on both sides for either window to work because it's still a complete circuit either way. Do you have another switch to swap into it? I think I have one out in the parts car that I could probably pull if you don't want to buy a new one.
95 Talon TSI AWD
97 Eclipse GST
gthompson97 is offline   Reply With Quote
Old 10-29-2006, 09:11 PM   #5
l_eclipse_l
I don't have another switch, and my guess is you don't have a black one.
I'm thinking about just buying another motor and swapping it in. If that dosn't solve it, then I can assume it was the switch and just resell the motor. Good idea?
I found this one real quick:
http://cgi.ebay.com/ebaymotors/MITSU...QQcmdZViewItem
'92 3000gt SL
Zoom Stage 1 Clutch
Old 10-29-2006, 09:15 PM   #6
gthompson97
You could do that, but a motor will be much harder than a switch. Maybe you should buy a switch and if that doesnt' solve it, get a motor? It's the easier, cheaper way to go IMHO.
95 Talon TSI AWD
97 Eclipse GST
Old 10-29-2006, 09:22 PM   #7
l_eclipse_l
You would think so, but finding a black switch might take awhile. I didn't see any on eBay, and I wouldn't buy a gray one just to prove that was what's broken. I figured if the motor didn't work, then the search for a black switch would begin.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 10-29-2006, 09:43 PM   #8
AbsoluteGTR
AbsoluteGTR's Avatar
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Just do what gthompson said....changing out switches will take 30 seconds. But putting in the motor will be the biggest bitch in the world to put in.
On my old 2g I had to put in a new passenger side window, and that was a HUGE pain in the ass. I seriously hate even thinking back to it. You hands have like no room to work. Just get a switch, you can live with a grey switch, or just paint it!
I bet that it is the switch that is not working or even the wires. I seriously doubt the motor would just fail.
AbsoluteGTR is offline   Reply With Quote
Old 10-30-2006, 10:42 PM   #9
xavier3jr
xavier3jr's Avatar
just buy a grey switch the buttons pop right off. all you have to do is pull the buttons off the black one and put them on a grey one.
garret go pull your passenger switch off and try to roll it down with the drive side i bet it wont roll down
Old 10-30-2006, 11:38 PM   #10
l_eclipse_l
From what I could see, the whole switch is a big piece of plastic that extends across the door panel where that little dip is. And I would be kinda scared to rip the buttons off lol. I tend to do more damage than good. I already busted off two of the little plastic clips holding the door panel on
Garrett is gonna see if he can get me the one off his parts car, don't worry.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 10-31-2006, 01:56 AM   #11
gthompson97
In our cars, one switch is a master switch, and one is a slave. If the master quits working, so will the slave, but if the slave quits, the master will still work, it won't be an "incomplete" or "broken" circuit if one of the switches doesn't work. If that was the case then neither windows would work any time something happened.
95 Talon TSI AWD
97 Eclipse GST
Old 10-31-2006, 07:33 AM   #12
Mikelb
Mikelb's Avatar
Send a message via AIM to Mikelb
Originally Posted by gthompson97
In our cars, one switch is a master switch, and one is a slave. If the master quits working, so will the slave, but if the slave quits, the master will still work. Now I don't know which side is the master/slave, but I know that it won't be an "incomplete" or "broken" circuit if one of the switches doesn't work. If that was the case then neither windows would work any time something happened.
Something I don't understand... my driver's side (master switch) will roll my passenger window down, but not up... I have to reach over and hit the passenger switch to do that...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Mikelb is offline   Reply With Quote
Old 10-31-2006, 07:00 PM   #13
gthompson97
Something is wrong with the drivers side switch for the passenger window.
95 Talon TSI AWD
97 Eclipse GST
Old 11-26-2006, 10:11 PM   #14
l_eclipse_l
Update:
Bought a new switch, no change. The power locks all still work great, but nothing from the passenger window from either the driver side switch or the new passenger side. Could it be anything else besides the window motor?
'92 3000gt SL
Zoom Stage 1 Clutch
Old 11-28-2006, 01:13 PM   #15
l_eclipse_l
Nobody has anything? I guess I'll just buy a used motor then.
'92 3000gt SL
Zoom Stage 1 Clutch
