| Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here. |
10-18-2006, 11:18 PM
#16
Re: camaro ss 1/4 and 1/8 times
i know a kid who has a 01 or 02 SS and all he has done is a catback and it is a A4 and he runs 13.3's.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
10-19-2006, 12:05 AM
#17
That thing got a Hemi?
is that definately all he has done?
could he have done other mods he hasn't told you about?
Seatbelts Saved My Life
10-19-2006, 12:37 AM
#18
Definitly possible.
2001 cougar 2.5V6 AUTO Trubendz catback,SVT uim and TB,K&N intake and someother non performance stuff
10-19-2006, 02:53 AM
#19
hmmm....10 seconds....stock motor.......got it.....th400 w/ a trans brake, 4" titanium composite driveshaft, ford 9" built rear end, and some 335 straight slicks. Launch at around 4000-5000 rpm and hold on  motor is still stock
might need to take a hammer to the fender wells though haha
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
10-19-2006, 10:52 AM
#20
no he said he is bone stock, he might have a k&n filter but thats all.
10-19-2006, 05:24 PM
#21
maybe hes just saying that.
when the guy was asking me about my car i told him that just about everything was stock, and it was only pushing MAYBE 200hp. he was like "damn man thats pretty good".
10-19-2006, 06:45 PM
#22
Firebird Guy
Unless conditions are 100% perfect, I can't see it without a stall.
But to some that leaves the motor stock.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
10-19-2006, 08:03 PM
#23
GM S-Series Mod
could very well be possible. ive seen a non ws6 ta with A4 run low-mid 13's with only free mods.
2000 Chevy Blazer ZR2
Performance: AEM intake, TB mod, ported stock y-pipe w/precat deleted, 3in catco cat, 2.5in Flowmaster 40 DF,
March pulleys, MSD SF ignition, Taylor 8.2 wires, Transgo shift kit, Corvette servos, B&M trans cooler.
Suspension: Knaffle 1.5in lift shackles, 1.25in rear wheel spacers, 31in BFG AT's
Exterior: custom ZR2 decals, bug guard, vent visors
Interior: Lanzar headunit w/ ipod input, Pioneer speakers, Scanguage II
http://www.cardomain.com/ride/3013891
10-20-2006, 04:43 PM
#24
holy @#$. imagine running 16psi in the LS1 @_@. thats like 600+ hp if you set it up right.. what do you need in our engines for that kind of boost?
(cuz 13 lbs is almost twice the power, right?)
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
10-20-2006, 09:21 PM
#25
Firebird Guy
Forged bottom end and lower compression.
Or of course...
You could go stroker with higher compression.
I have hung with a 375 LSx with a front mount turbo at 9 PSI. From the start I pulled him hard, once he got into boost he was slowly pulling on me.
In other words...I think I could pull a stock cubed LS1 with 10-11 PSI from a turbo.
Stock'ish'
10-25-2006, 09:53 AM
#26
i know a dude that stroked his LT1 to a 383 and runs nitro though it for high 10's or low 11's in the quarter. he trashed the motor when it was stock with nitro runnin through it by spinning a rod bearing or something
10-25-2006, 10:41 AM
#27
Firebird Guy
I can go low 11's full weight with just my motor.
Maybe REALLY high 10's.
Full weight street car.
Stock'ish'
10-25-2006, 10:51 AM
#28
Most Seniorest Mod EVER!
Never was a fan of the juice but alot the force induction guys use it for cooling effect and spool time. I always thought of it like a guy on steriod's. Totally artificial but then again I guess the same thing might be said about blowers and turbos, so to each there own.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
10-25-2006, 03:39 PM
#29
Originally Posted by eclipsed at 3am
as for my car, im running 16 for daily driving. With the 550 injectors i can positivly and safely run about 21psi. much more than that, and i dont trust my head gasket or piston rings. I've only been to the track once and it was an 1/8 mile, and i ran a 9.3 at 85 mph at 16 psi, which is ok i guess..
this guy wants to meet up at the same track and run it a week from today. i think ill go for it.
That's a good trap for the 8th. Your 60' must have been pretty rough, cause you have the power for 8s easy. Everyone I see that traps in the mid 80s has ETs in the mid to low 8s
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
10-25-2006, 05:36 PM
#30
it was my first time at the track, so i was a little unsure of how this was gonna work out. also, normally my launch is horrible, on the street. so i tried to take off really smooth, still burned for about 15 feet or so. my r/t was like .8
