| Latest | 0 Rplys |
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
10-01-2006, 05:46 PM | #1 | |
96 Firebird Gas Odor Problem.........
Hello again! I dont know if many remember me but I had purchased a 1996 FIREBIRD from an auction. It was a fresh water flood recovery with only 54,000 miles on it. I had spent a good 6 months trying to repair the car. right now it is in MINT condition. it has 54,000 miles on it now (1 year later) and I had to replace the power window motors over the year. everything is fine now except for this major problem:
when I get into the car at times, I would smell "raw gasoline" within the car. It doesnt happen all the time. My mechanic noticed it as well and they tried looking for the cource but were unable to find it. Im kind of scared now because I heard on the news that a man was burned alive in his car by a simalar incident. He was smelling raw gas in the car and he was going to take it the shop the next day but a witness said they saw a "spark" in the car then the whole entire interior of the car was engulfed in flames, taking the mans life. does anyone know what is the matter? I dont recall any gaslines going into the interior of the car. thanks! |
10-02-2006, 02:47 AM | #2 | |
Re: 96 Firebird Gas Odor Problem.........
i have the same problem..try get your car scanned fora code, my car has the code for the charcoal canister, or the 'purge canister'..
Car: 1997 M6 SS Camaro [ white ] 285's in the back all else = STOCK. |
10-02-2006, 07:49 AM | #3 | ||
thanks, but I dont understand how the purge canister would have anything to do with it. I know some stuff about cars but how will this allow a gasoline odor in the car and not outside? |
10-02-2006, 06:15 PM | #4 | |
something about the purge canister letting gas in/out.. im not really sure about that eithier..but my car started smelling like gas after i heard a 'pop' while filling up the tank..soon after, the CEL went on for the purge canister...so.. i sort of put the two together..
10-02-2006, 06:16 PM | #5 | |
*gas vapor..etc.. (not to sure on thsi topic.)
10-02-2006, 06:26 PM | #6 | |
I told my mechanic that it would give off a code and he said when he scanned it with the comp, it gave no code. He then said he too, smelt the gas then when he put it in the bay/life, the gas odor was gone after starting it.
so, it seems that my problem seems to be when the car sits for some apparant reason. |
10-04-2006, 06:46 AM | #7 | |
Any chance the seal/gasket at the top of the tank is leaking/faulty? That may cause a smell that gets worse as it sits. Also, if the gas cap was left loose...though that would probably smell stronger outside the car as wella s set off a code and check engine light...just trying to throw some things out there to look into.
10-04-2006, 07:02 AM | #8 | ||
10-04-2006, 07:47 AM | #9 | |
Ok, ive narrowed it down to this:
when I start the car in the morning: its fine. I drive around for a while, then park it. it will sit for 20 minutes then I get back in the car, I smell gasoline it happened twice already this morning. |
10-06-2006, 06:27 AM | #10 | |
Well, it basically doesn't happen until the fuel system pressurizes then it sounds like. So its not going to be things like gas caps. Could possibly be a leaking fuel line under the car...though that should smell outside the car as well...honestly, anything having to do with the fuel system that is leaking and causing an odor in the car should be smelt outside the car too. it may just be that the wind and outside air are overpowering/clearing the smell away where as in the car it lingers due to the lack of ventilation. Check your fuel lines...otherwise Id have to go with the canister as well.
10-06-2006, 07:05 AM | #11 | |
thanks, it sounds like the canister is the only viable culprit. We couldnt figures anything else out. no leaks anywhere on the gas lines, tanks or anything. I will check the canister out and let you guys know. thanks!!
10-22-2006, 03:08 PM | #12 | |
hey, i know i'm kinda late joining this topic but i was wondering if you had replaced the canister yet and wether or not it worked for you,because i have the exact same problem with my 96 bird. also wanted to know if its a replacement i can do myself?/part cost? thanks, john
10-24-2006, 01:59 PM | #13 | |
If its not throwing ANY trouble codes, the problem could be a leaking injector or injector seal. Once the car is off, fuel could be wasting past the injectors into the fuel rail, or it could be a injector seal is dumping fuel onto the top of the motor. Either way you should only be able to smell it standing down wind from the tail pipe. You could have an exhaust leak under the belly of the car. I would be more worried about brain damage from exhaust fumes, than your car exploding with you in it.
08-03-2007, 07:59 PM | #14 | ||
The smell of gas that it was is not the vapor gas. its actual "raw" gasoline I smell right after I stop the engine. |
08-03-2007, 09:47 PM | #15 | |||
Maybe gas fumes are getting to me also |
