| Latest | 0 Rplys |
09-30-2006, 09:58 AM | #1 | |
transmission fluid change
Hello Kia Owners out there. At the last minute, we had to borrow my father-in-law's 2005 Kia Sedona van for a short weekend vacation. Our reliable Chrysler T&C spit out the serpentine belt and I wasn't home to fix it. Anyway, the Kia has 31,000 miles and the transmission fluid (ATF) is the same color as the engine oil after 5000 miles of running. The tranny shifts OK, but I was expecting it to be a little pinker than it was. My father-in-law is a great guy, but vehicle maintenance is not high on his priority list. The engine oil hasn't been changed in 8000 miles, was almost a quart low and the tires were at 25 psi all around, and my wife drove the thing 500 miles this way.
What I need to know is, what type of ATF is recommended for this vehicle and what is the recommended ATF change schedule? ...and before you ask, NO, the owners manual is not in the car! Any help would be appreciated. Oh, on the subject of drain versus flush, flushing is not mandatory. Yes, it does remove most of the old fluid at once, but unless you have a rack and proper flushing equipment, a real hassle. My suggestion, for the do-it-yourselfers is to drop the pan once, refill, drive a couple hundred miles and drain again. Or, just drain and refill once every 15,000 miles and replace the filter every other drain. Remember, once you start to drive the car again, contaminates start to return in the fluid, so the benefit of flushing is short lived.
"This car may be old, but it will still climb Kirker Pass at 110!" 1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible |
10-03-2006, 01:51 PM | #2 | |
Re: transmission fluid change
30000 miles use SP3.
Dextron will tear up the trans and fast. I recommend flushing when ever possible.
http://www.indyspeedandchrome.com |
10-03-2006, 07:24 PM | #3 | |
This is the first time I have ever heard of SP3 ATF. At the local auto parts store, all I could find was Dextron III/Mercon, ATF+3, ATF+4 and Type F. I use the first in my old Chryslers, my Volvo, my Father's Town Car and my Father-In-Law's Aerostar vans; and the next two types in my modern Chrysler products. I don't own anything that uses Type F.
Where in the world does someone get SP3 fluid? ...the Kia Dealer only?!? ..or are there other manufacturers that use this new fluid? Any additional information would be helpful.
10-04-2006, 10:06 AM | #4 | ||
10-04-2006, 05:59 PM | #5 | |
One more questions, is SP3 fluid the same color red as all other ATF, or a different color? I'm worried because the ATF in my Father-In_Laws Kia looks brown at 32,000 miles. If it started out red, it ain't red anymore.
06-21-2007, 05:53 PM | #6 | |
does anyone has instruction how to change the tranny fluid for sedona? I read the valvoline book at pepboys suggest remove the tranny hose from tranny to cooler, start the engine for 1 min or until it stop drainning, then fill the new fluid at the stick hole. It sound scary to drain the fluid while the engine is on. I don't think the tranny has a drain plug at the bottom. Is there anyone know how to change it?
06-26-2007, 10:23 AM | #7 | |
Try this link.
http://msw.kiausa.com/viewer/default.asp?group=shop |
10-27-2008, 03:07 PM | #8 | |
Recommend you buy the fluid at the dealer -- $6.85 / quart, takes 15 quarts. This car as a tranny cooler. The same system cools the transaxle.
05-31-2009, 11:51 PM | #9 | |
Anyone out there know where I can locate a transmission oil filter for a 2004 Kia Carnival, 2.9L Diesel ??
08-27-2009, 11:41 PM | #10 | |
there is at least on 02 models,,,,,a plug on the bottom of gear case,,,which gets the gunk out of the bottom of trans ,,02 version has no bottom pan
08-28-2009, 07:19 AM | #11 | |
transmission flud is actually clear when it's made, they dye it red. Dye turns brown pretty easily. Clutch material only adds to the color. Flushing with a machine is the best route, a drain and fill will get you about 4 quarts of fluid changed.
09-04-2009, 08:15 PM | #12 | |
how to change transmission oil filter on a kia sedona ,2002
09-05-2009, 12:21 AM | #13 | |
the filter is internal,,,no oil pan,,,,best you can do is drain tranny,,,is a plug in case to do that....
10-31-2009, 10:08 AM | #14 | |
My tranny does'nt shift when hot it runs in low . I verified the fluid leve and it seems to be over fill. But ican't recognize wen if over fill
Thread Tools | |
