SRT-4 exhaust ins't needed nor required and you use the STOCK PCM with either a missing link or MAP clamp.
i did some research on the MAP clamp....is there anyway to tuneit without the dyno? and will i still need this if i got the
APEXI SUPER AFC 2?
Stuff needed would be SRT-4 turbo/manifold, oil & coolant lines along with fittings, map clamp, intercooler and piping, turbo 02 housing, downpipe, bigger fuel pump, bigger injectors, and a fuel pressure regulator. You can get a boost controller if you'd like, but won't be necessary if you are running th stock 4 psi.
whats the turbo 02 housing??
again thanks for all the help!!....im totally new to turbos but i really wanna learn and get started with them!
