Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 07-19-2006, 10:39 PM   #16
blazes9395
Newbie mod
blazes9395's Avatar
blazes9395 Normal reputation
Re: transmission problem
Originally Posted by blazee
*Edit* If I read your reply right, this all started after you changed the fluid and filter, is there a chance that you knocked the harness loose?
Exactly what I was thinking, and you could have knocked loose/ or damaged it when you were doing the oil/fitler change. Are you sure you didn't damage the solonoids inside the tranny when you were pulling the pan down and out, they can be damaged very easily.
blazes9395 is offline   Reply With Quote
Old 07-19-2006, 11:02 PM   #17
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
What about a bad VSS?
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 07-20-2006, 04:04 PM   #18
carjimost
carjimost Normal reputation
ok i checked the trans fuse and is good then i checked the wiring harness and it looks good it is connected to the tranny. i don´t know if there is a ground wire that i should check
carjimost is offline   Reply With Quote
Old 07-20-2006, 04:07 PM   #19
carjimost
what is the vss? how can i check it
Old 07-20-2006, 04:28 PM   #20
BlazerLT
AF -Advisor
BlazerLT's Avatar
hicle speed sensor.
On a 4x4 I think it is on the transfer case and on a 2x4 it is on the tail shaft of the tranny.
If the computer is not getting the proper signal from it, it will mess things up completely.
Old 07-26-2006, 03:07 PM   #21
carjimost
hi everybody finally today i have time to remove de oil pan and check the solenoids what i found was that the 3-2 downshift solenoid was disconected now my quiestion is do you thing all these codes P0753, P0758, P1864 AND P1886 ARE FAILING BECAUSE THE 3-2 DOWNSHIFT SOLENOID WAS DISCONECTED
THANKS AGAIN FOR ALL YOUR HELP AND PLEASE GIVE ME SOME ADVISE
Old 07-26-2006, 03:58 PM   #22
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Kinda hard to say but that is a good start.
Hook them all back up and clear codes and drive it and see whatit does.
Let us know how it goes.
MT
MT
MT-2500 is online now   Reply With Quote
Old 07-26-2006, 06:11 PM   #23
carjimost
Smile Re: transmission problem
Hi again, I just plug in the solenoid that was unpluged replace the filter and tranny fluid and the truck works great, smooth shifting and everything works excellent. I really I appreciate your help and it was really helpfull i learn a lot from you. This is my first experience in the forum and I´m happy with the results thank you one more time i was sad and I was thinking in selling my blazer but now i'm very happy with my truck THANK YOU EVERYBODY.
Old 07-26-2006, 06:24 PM   #24
MT-2500
AF - Advisor
MT-2500's Avatar
Thanks for letting us all know how it went.
Glad all is well.
MT
MT
Old 07-27-2006, 09:58 PM   #25
BlazerLT
AF -Advisor
BlazerLT's Avatar
Great work!
Bookmarks
Google
Web AF
