Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > LS400/LS430/Celsior
Old 07-15-2006, 06:10 PM   #1
josh1
josh1 Normal reputation
1993 lexus ls400 will not crank
I have a 1993 ls 400 the vehicle has 111000 and the timing chain was replaced at 108k i am having problems with the vehicle cranking first it would not crank and after setting a while it would crank cold or hot. i took it to the mechanic shop and $1000 later i was informed it was the oxygen sensor i replaced that and the same thing happened. after that i replaced the fuel filter the fuel pump the crank sensor and the coil pack it will not crank. after i replaced the crank sensor the vehicle cranked and the next morning the vehicle would not say anything. i was told by a mechanic that the vehicle was not fireing could someone please help.
thanks,
josh1 is offline   Reply With Quote
Old 01-19-2008, 11:43 AM   #2
swiftknight23
swiftknight23 Normal reputation
Re: 1993 lexus ls400 will not crank
it could be one of three things. 1. your timing belt is still off, this could cause the plugs to fire at the wrong time. 2. faulty sparkplugs, to much carbon build up, ect... and finally 3. you might need to replace your distriburtor. if its defective it will cause a loss of spark. anyway i hope this helps.
Terrell
swiftknight23 is offline   Reply With Quote
Old 05-18-2008, 01:49 PM   #3
Wil C
Wil C Normal reputation
will it crank but not start?? or just not crank at all.
Wil C is offline   Reply With Quote
Bookmarks
Google
Web AF
