I bought both a 1990 Galant GSX and a 1991 Galant VR4. The VR4 was in an accident and is totalled, not even worth salvaging as far as i could tell because the cross member was in the wrong spot. It just so happens that the cross member being shoved over means the engine in the GVR4 (which was freshly rebuilt) had the front mount torn off the block (holes and all). So that block is toast.
The Galant VR4 is 106/2000 for those of you keeping track. It is quite literally the earlist Galant VR4 i have EVER seen.
I tore out the interior of both cars and am in the process of putting the Galant GSX back together with the wonderful leather interior that was in the VR4. The wiring harness was swapped as well as the Eprom ECU.
The dash is also being swapped in, badge and all.
With the car came some very mild goodies. I received a ported 14b turbo, 2.5 inch TBE, new K&N filter, new battery, mbc, turbo-timer and an A-pillar mounted dual gauge pod with boost and EGT gauges. I recently bought 194NA bulbs to replace the standard bulbs on it, so that it would match the factory amber color. I have also just finished the wiring so that the gauges wont' be on unless the car is on, and the factory foglight switch is in the "on" position.
Both cars came with brand new tires.
I'm also swapping the brakes over and am planning on replacing the lines with new factory hose. The brakes are the ones on the VR4, so they are fairly large and stop very well.
I'm still a long way from being finished and hit a snag when i found out the engine wasn't going to just drop in. Otherwise i'd be driving the thing around now and picking on some poor ricers.
Things left to do:
wire in the relay for gauges/fogs
swap rear ends/driveshafts/axles/hubs front and rear.
rebuild the engine on the n/t block that came from the GSX
put the rest of the interior in.
swap the tinted windows from the VR4 on to the GSX
get an EGT probe for the gauge (it is lacking)
Long term plans(next summer):
Evo3 16g turbo
2g ported ex. manifold
evo 8 FMIC
550cc injectors
IC sprayer
meth/h2o injection
harpipes
GM 3" blow thru
dsmlink
hard pipes for EVERYTHING
Relocate the battery to the rear
maybe a 4 bolt rear end
and hopefully 25lbs of boost
and that should put me in the 12's
The thing should be running and driving around by the end of july, but again, no promises
Thanks to Rob (cassiesman), Trent, Ramone, Rasmey, Adam, Stu, Malcolm, and Kim for helping me take this thing apart and put it back together. I really couldn't have done it without you guys (well maybe, but its nice having you all around)
^^ me before i learned the front mount was broken because ... at that point, all we had to do was hook it up and start it. I have a very pissed off persona about me now because the fudgin' thing is BROKEN!!
