Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Camaro Discussions
Old 05-31-2006, 10:01 PM   #1
TinyRulz
TinyRulz's Avatar
Do I need a Muffler?
I switched my muffler on my camaro today from stock to magnaflow, While I was changing it I ran the car around the block with no muffler and it sounded GREAT But will it hurt my motor to run it like that because I have a gutted cat.
1993 Z-28 Camaro
So can I run it with no muffler?
TinyRulz is offline   Reply With Quote
Old 05-31-2006, 10:11 PM   #2
98BlackTransAm
98BlackTransAm's Avatar
Send a message via AIM to 98BlackTransAm
Re: Do I need a Muffler?
1993 Z-28 Camaro
i dont think running it w/ out a muffler could really hurt the engine,, that'd basically just be straight pipes..altho that's def not street legal. i'd go with a cutout, which isnt street legal either, but it's slightly more refined and a little less noticeable than just having no muffler. just cap the cutout when you get it inspected and don't go above 2k rpms in front of the po-po
2002 Firehawk (M6) http://www.youtube.com/watch?v=6XKnrV7c_Bs
F13 cam (230/232, .595/.585, 112+4 LSA) | PRC Dual Valve Springs | LS2 Timing Chain | Ported LS6 oil pump | Pacesetter LT's | TSP catted y-pipe | Flowtech cutout | LS6 intake | SLP lid | SLP cat-back | Bilstein suspension | Tuned by Mayhem Motorsports
1998 Pontiac Trans Am (A4) - SOLD
slp lid, pacesetter lts, ory, flowtech cutout, fuddle 3400 stall, B&M tranny cooler
98BlackTransAm is offline   Reply With Quote
Old 06-01-2006, 01:20 AM   #3
Savage Messiah
Savage Messiah's Avatar
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
won't hurt your engine, just your neighbors' ears
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Savage Messiah is offline   Reply With Quote
Old 06-04-2006, 12:23 PM   #4
NoRiceHere01
it will only hurt the engine if theres not enough pipe to dissipate the heat of the exhaust.even if its a straight pipe it wont hurt if it runs all the way out to the back of the car.if u run a cutout and its right off the headers its not a good idea to leave it that way.with a pipe that short it will eventually build up enough heat to burn the exhaust valves.plus if theres no backpressure at all u will lose any bottom end torque the engine has.as cool as open headers sound it is better to have a properly tuned exhaust.i wouldnt worry about it bein legal tho.if the cats gutted then ur already illegal haha
NoRiceHere01 is offline   Reply With Quote
Old 06-04-2006, 12:44 PM   #5
98BlackTransAm
you will lose a little low end torque with open exhaust (not sure how the open headers work performane-wise) but it basically just moves the torque curve up and gives you better performance in the long run (i.e. 1/4 mile times). you shouldnt have to worry about burning the exhaust valves if you install a cutout down the I-pipe closer to the muffler rather than right next to the engine. should also net you 1-2 mpg as well (assuming you resist the temptation to make it growl everywhere you go )
Old 06-04-2006, 02:28 PM   #6
NoRiceHere01
no it wont hurt if its down the exhaust.sorry i didnt mean to sound discouraging haha i was just assuming he was gonna put it on the header cuz thats probably what i would do
Old 06-04-2006, 04:58 PM   #7
98BlackTransAm
haha it's str8,, and open headers sound mean as shit imo
Old 06-04-2006, 07:11 PM   #8
Savage Messiah
you're right on for the first part, except I'm pretty sure it's the cold air that can work its way up to the valves and crack them. Vavles are right in the combustion chambers, they're used to heat, it's when the cold air hits the other side that they crack
Other thing is oen that really gets t me, YOU DO NOT NEED OR WANT ANY BACKPRESSURE. backpressure is BAD. What people commonly mistake for backpressure, what you want, is exhaust velocity... if your piping is too wide or too short then you lose velocity at lower RPMs which will cost you torque. More velocity is better... less backpressure is better.
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 06-05-2006, 11:50 AM   #9
demon9766
Send a message via Yahoo to demon9766
savage is right if you have back pressure that means that your motor is choking out and won't run well. if he has long tube headers with cutouts it won't hurt a thing i do it all the time and still make the torque to pull the passanger tire off the ground.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
demon9766 is offline   Reply With Quote
Old 06-05-2006, 06:21 PM   #10
NoRiceHere01
yes but u also have an engine thats tuned for that kind of exhaust.the cam in his car is not one thats designed to have just open headers on the engine.i have 2 mufflers on my truck right behind the cats and nothing after them and it works fine, but if i take the mufflers off i have no bottom end.i cant imagine it would improve his launch any if he were to run nothing but open headers.ur engine is a bit more extreme than most of ours lol.and whether its cold air or heat dissipation if he were to run just open headers on a regular basis it would burn his exhaust valves.my friend blew out the donut that seals his manifold to his pipe in his pickup and it soon burned all 4 exhaust valves in that bank of cylinders cuz he was too dumb to replace it.it does sound sweet with open headers and with a full exhaust and no muffler its perfectly safe.im just tryin to save him any trouble if i can
Old 06-05-2006, 11:19 PM   #11
TinyRulz
TinyRulz's Avatar
My friend has a 1/8 and 1/4 mile timer that you place on your windsheild that tells you your power, speed, and time I tried it on my Z-28 with my Magnaflow, Stock, and No muffler and without anything it was 1.657 Seconds faster in 1/8 and about 1sec. in 1/4 why is that?
Old 06-05-2006, 11:59 PM   #12
AlmostStock
AlmostStock's Avatar
Because the timer is not accurate? There is no way simply removing your muffler is going to gain you a second in the quarter.
Mark's Garage est. 1983
AlmostStock is offline   Reply With Quote
Old 06-06-2006, 04:02 PM   #13
NoRiceHere01
thats what it sounds like to me.it takes quite a bit to just knock a second off a quarter mile time.how many times did u run the car with each exhaust setup?
Old 06-06-2006, 10:39 PM   #14
TinyRulz
TinyRulz's Avatar
I ran them all once. I did it again today and got my friend to set it up for me and It's still faster with no muffler but nowhere close to the number's I got last time.
Now it is a 13.25 @ 107 no muffler
13.47 Magnaflow
13.90 Stock
Does that sound better.
Old 06-07-2006, 04:04 PM   #15
NoRiceHere01
that sounds better.when u ran it with no muffler u still had a full pipe going to the rear of the car correct?
