Go Back   Automotive Forums .com Car Chat > Ford > Crown Victoria
Old 05-14-2006, 04:35 PM   #1
gregfor1
ball joint
can anyone tell me what the torque spec is for a lower ball joint on a 99 crown vic? thanks for the help. I am doing the right side.
gregfor1 is offline   Reply With Quote
Old 05-15-2006, 02:19 PM   #2
way2old
TOKEN HILLBILLY
way2old's Avatar
Re: ball joint
See if this helps.
SECTION 204-01: Front Suspension 1999 Crown Victoria/Grand Marquis Workshop Manual
SPECIFICATIONS Procedure revision date: 04/04/2001
Torque Specifications Description Nm lb-ft
Front suspension lower arm-to-frame 175 129
Front suspension upper arm-to-frame 175 129 Stabilizer bar link-to-front wheel spindle nut 30 22
Front suspension upper ball joint-to-front wheel spindle nut 90 66
Front suspension lower ball joint-to-front wheel spindle nut 175 129
Front stabilizer bar-to-frame bolt 70 52
Shock absorber upper nut 40 30
Shock absorber-to-front suspension lower arm bolts 15 11
Stabilizer bar link-to-front stabilizer bar nuts 55 41
Front axle wheel hub retainer 300 221
Wheel nuts 129 95
Tie-rod end-to-front wheel spindle 55 41
Front suspension bumper nut 40 30
Upper ball joint-to-upper control arm nuts 160 118
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
