| Latest | 0 Rplys |
05-03-2006, 01:57 PM | #1 | |
Bad Engine
I just found out that the #7 piston is @ 25 PSI. They tell me that I need to rebuild the entire motor, it will cost about $2,500 dollars. I have a 4.1 engine in the car. Q, can they just fix the bad piston or should I go and have the entire motor redone. The car has over 140,000 miles on the meter. HELP
05-03-2006, 02:29 PM | #2 | |
A990 racer
Re: Bad Engine
Get a 4.5 Cad engine, direct replacement, quite a few suppliers out there also try GM Goodwrench engines. The 4.1 was bad from day one, don't waste money fixing yours.
05-05-2006, 11:51 AM | #3 | |
Re: Bad Engine
OK, I'm having low pressure (25 psi) on my #7 cylinder, will I need to replace the motor or just fix the cylinder? HELP Me OUT!!
05-05-2006, 02:23 PM | #4 | |
A990 racer
Re: Bad Engine
You do not know what is wrong till you pull the and head/or piston, also check the camshaft this was another problem, how can anybody answer your question without knowing the exact problem?
09-11-2006, 05:59 PM | #5 | |
Re: Bad Engine
Well I broke down and replaced the motor with what else a new 4.1 out of the box. I just can't see myself changing the motor to some other C.I.. See runs great now.
